A3 1.8T some errors/problems...
andreagtr
NULL
Hi everyone, i'm Andrea from italy (please forgive me for my bad english :)), i've buy an old A3 with some problems...
The first scan with vagcom:
Thursday, 13 June 2013, 19:04:50
VAG-COM Version: Release 409.1-S
Control Module Part Number: 06A 906 018 D
Component and/or Version: 1.8L R4/5VT MOTR HS D02
Software Coding: 04000
Work Shop Code: WSC 00000
6 Faults Found:
01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
29-00 -- Short to Ground
00529 - Engine Speed Signal Missing
06-00 -- Signal too High
16499 - Engine Coolant Temp Sensor (G62): Supply Voltage
P0115 -- 35-00 - -
16522 - Oxygen (Lambda) Sensor B1 S2: Signal too High
P0138 -- 35-00 - -
16511 - SAE: Intake Air Temperature Too High
P0127 -- 35-00 - -
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 -- 35-00 - -
After, i found the IAT and BARO sensor sconnected, ive reconnect them (the baro was faulty, then i have repaired it), the N80 its really short to ground, then i have disconnect them before i replace it.
Now the scan show this:
Wednesday, 19 June 2013, 18:54:01
5 Faults Found:
P0115 -- 35-00 - -
P0138 -- 35-00 - -
16533 - Fuel Trim System (B1): Discrepancy in Injection Times
P0149 -- 35-00 - -
But if i clear the DCT when the engine its on, the DCT are theese:
Friday, 28 June 2013, 19:20:2
2 Faults Found:
26-00 -- Output Open
16487 - Mass Air Flow Sensor (G70): Signal too High
P0103 -- 35-00 - -
The maf its really clean, recently i have connect an old boost gauge, and the boost pressure its 4/5 psi, if i disconnect the n75 th pressure its the same, but if i sconnect the pipe to the wastegate the boost goes up (a very very shrt and lightly test)but not very quckly ( i repeat, i never test in WOT with the pipe sconnected..., i think i have tryed in 1/3 gas...)
My question is:
where do i start?? :)
I never see an engine light goes on, but is there a way to verify if i run in recovery mode???
theese errors can goes the boost pressure low??
With the pipe sconnected, the pressure goes up, it mean there is no leak?
Im glad to be here, i hope you can help me, thanks to all!!!
Greetings
I
953
