EM TuningVolks Autos
Results 1 to 19 of 19
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    Facelift head lamp guys on pre facelift cars.
    Hi just a quick question.
    Are any of you guys with the 1.8T having problems with the headlamp adjuster rubbing on the intercooler pipe on the drivers headlamp?
    As mine seems to be trying to rub a hole through the pipe! I've wrapped foam around it etc... but it still rubs through that.
    I am using the older adjusters that are bigger as I couldn't wire up the newer smaller ones, but I am sure most people are running the older ones?
    So guys is it just me? Or others?
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    Re: Facelift head lamp guys on pre facelift cars.
    TTT
    Cheers guys
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    Last bump.
    As it must just be mine [img]/ubbthreads/images/graemlins/frown.gif[/img]
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    I think there is a lack of people on here that have actually done it Mark [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    That's what I was thinking, oh it's good to be different sometimes LOL
    So has anyone got any suggestions to what I could wrap around the pipe to stop it trying to rub through?
    As the foam keeps on either falling off or wearing out.
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    some kevlar... or carbon fiber should do it... if you can find any... [img]/ubbthreads/images/graemlins/idea.gif[/img]
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Time to invest in smaller adjusters?
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    [ QUOTE ]
    [/ QUOTE ]
    Got some in my garage, but I couldn't get the existing wires to work with them. Hence why I am using the larger old style ones.
    Aug 2003
    Surrey
    469
    I thought khufu had put new lights in? Or was it old shape xenons? I'm sure he did something with his lights..
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    How do they differ?
    Is it just a case of removing the existing plugs and fitting the later style jobbies?
    You can get the bare plugs and clip in wires from the stealer for next to nothing.
    I've been round my car recently and renewed some stuff this way and its really easy to do.
    Chuck up some photos if you get time.
    Khufu's Avatar
    West coast of Scotland
    5,693
    I fitted the old style xenons in mine, not the facelift ones. Also i have plenty of space in my engine bay as I dont have a turbo [img]/ubbthreads/images/graemlins/frown.gif[/img]
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    [ QUOTE ]
    [ QUOTE ]
    [ QUOTE ]
    [/ QUOTE ]
    [/ QUOTE ]
    How do they differ?
    [/ QUOTE ]
    When I get chance I will take some pics, but from what I can remember the plug is larger. So I cut the attachment on the newer adjuster to allow it to fit, but then it did nothing when I tried adjusting it.
    Maybe wrong voltage or something, but I left it at that and just used the old style larger ones.
    Nov 2004
    cambridge
    75
    My drivers side lamp is broken, where did you get the facelift lamps from?
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    You can get them from Audi (obviously), an online breakers which deliver to your door, or http://www.carlamp.com/cart/page/index.html or www.gsfcarparts.com (for just the lenses), or www.vagparts.com.
    239
    hi mark
    yep i noticed how close the pipe was when i fitted the new lights, i simply moved the rubber bracket ring thing up the pipe a bit so that touched the motor rather than rubbing the pipe itself. Not sure whether that is still protecting the pipe, i'll check when i go for lunch!
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    Hi settle if you could have a look that would be great. As I've wrapped some more foam around it today for a short term solution, but I think I'm going to have to wire in the facelift smaller one.
    Here are some pics of the problem and the smaller butchered adjuster:
    As you can see it is resting right on the pipe.
    Also you can see the butchered adjuster. Not that it matters as I've got the passenger side one that I could either use or take the connector off.
    I will try it again at some stage, but when I tried it before it did nothing. Maybe the wrong power supply?
    elucidate's Avatar
    Dec 2005
    Berkshire, UK
    157
    Aaaah, I was interested in watching this as I am in progress buying some new style headlamps.
    Keep this thread updated when you come up with a solution please :-)
    239
    well done mark!! i wouldn't of bothered checking the pipe again, but luckly i did and the bit of rubber i had wedged in to protect the pipe had almost worn through, i have just unplug the motor til i can have a better look. As you i also have the old motors so will also see if i can get them to work
    Markb's Avatar
    Apr 2004
    Midlands, Staffs
    2,136
    Yeah I've not got time to mess about getting the newer style ones to work. So I think I will just remove it like you have for now. Although there is quite a worn patch on my boost pipe now!
