JMB RetrofitsChris Nott
    Feb 2013
    Derby
    15
    Help and possible solutions needed please.
    Hi all, iv got a 2001 facelift 3 dr Audi a3 pd130, I'm seeing if anybody knows anything about a couple of probs I got.
    Here it goes..........
    First when I cruising at over 55mph it sounds like the wind is coming through somewhere as I can hear it whistling into car, but not sure where??
    Secondly when I accelerate the noise of the turbo spooling has got louder, now iv read these do sound loud but I'm not sure, think there could be a leak somewhere, anybody know possible causes ie pipes leaking etc?
    And last one the cars done 66k and I noticed it was becoming abit tappie with the revs, idle u can't hear it but when I'm driving the tapping gets faster, I had a full service to see if it neede it but its still the same, any ideas on this?
    Cheers in advance for any info and help etc.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    878
    Add Vex182 on Facebook
    Hello. Well for a start, 66k is not even worn in with one of those engines! A few of my mates have the in golfs and boras at 150k and 195k. Yes the turbo is pretty loud, even on the 90bhp models. Have you checked the oil level? Perhaps when it was serviced, they did not top it fully up and so it sounds tappety. What grade of oil has been used? Does the car feel less torquey than before?
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    Feb 2013
    Derby
    15
    Thanks for reply, ain't managed to get on untill now.
    I've checked oil not long after an it looked ok, as for grade I'm not sure but it was at a Audi, vw specialist so hoping they know what they doing lol.
    Ermmm does seem abit lack but still pulls. Going to check the pipes and stuff see if any leaking, is there a way of checking easier?
  1. Audi A4 Convertible/Cabriolet roof problem and possible solution
    By NickRB in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd August 2013, 21:33
  2. wheel spacer and spring tips needed please.
    By slim boi in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th April 2011, 18:53
  3. Gaskets for Turbo and Exhaust Manifold needed please..
    By mo_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th September 2010, 13:54
  4. New guy needs help and advice before purchase please?
    By boddhi in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th November 2009, 18:47
