Results 1 to 7 of 7
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    440
    MK4 Golf Suspension Compatibility
    Hello people,
    Just a quick question I can't seem to find the answer I think maybe its a bit specific. I have picked up a set of brand new MK4 golf suspension with Apex 40mm springs. They state they are for a MK4 Golf Diesel, should these fit my 1.8t A3 8L?
    Mar 2013
    Devon
    614
    yes they will physically fit.
    If they were from a 6 speed diesel then the fronts may be a different spring rate, may sit slightly high.
    Do they not have part numbers on them?
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    440
    Quote Originally Posted by JimS3 View Post
    I see, they were for the guys 150bhp diesel, which I am guessing is 6 speed. Springs just state they are for either V5 or Diesel MK4 Golfs. I don't have the struts part number but im guessing theyre the same. I suppose I could just flog them on.
    Apex Springs:
    Supplier Part #: AP80-7010
    ECP Part #: 974440971
    Golf mk4 Lowering Springs + struts | eBay
    Mar 2013
    Devon
    614
    if your fitting them yourself then why not give them a go, may well sit fine.
    If your paying a garage to fit them them then perhaps think about getting springs you know will be fine so the labour costs don't add up.
    I used to run 1.8t koni springs on a diesel golf and it sat and handled ok.
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    440
    I understand thanks. So are the shocks just the same and its only the springs that differ... because they are stiffer as theyre intended for a diesel (heavier)? I am talking about standard shocks here!
    Pubemammal's Avatar
    May 2013
    Braintree Essex
    440
    OK I've done some research, shocks for the GT TDI are the same part number for the A3 1.8T, so its only the springs that are different. The springs for the diesel are firmer to take the extra weight of the diesel engine, so basically my car will sit higher as it has the lighter 1.8t engine. I just dont know how much higher? Theres no point paying for them to be fitted if theyre going to sit at the same level or higher than my car currently is?!
    stevegti2's Avatar
    May 2011
    223
    i have some mk4/a3 1.8t koni springs for sale if youd rather them brand new in the box £60 i have the same on my a3 they sit nice im in kent bexley
    BURN RUBBER NOT YOUR SOUL !
  1. Does the 8L S3 share its suspension with mk4 Golf 4motion and R32?
    By Nogmeister in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd June 2012, 21:18
  2. Brake Pads for our Mk4 Golf Gti Anni
    By AL_B in forum Awesome GTI
    Last Post: 13th February 2007, 15:14
  3. Mk4 Golf R32
    By klauster in forum The Cool Wall
    Last Post: 30th January 2007, 09:51
  4. MK4 Golf Alloys
    By JohnK in forum Volkswagen and other VAG
    Last Post: 30th August 2005, 13:10
  5. MK4 Golf GTI
    By lb26 in forum Volkswagen and other VAG
    Last Post: 16th October 2004, 08:01
