Volks AutosAH Fabrications
Like Tree1Likes
  • 1 Post By Nilz
Thread: Random lack of power, VCDS fault codes: 17705 & 17963
    Jan 2012
    21
    Hey guys, as mentioned in the title I'm having issues with my 1.8t (2001, AUM, completely standard engine). It'll sometimes run fine (as far as I'm aware anyway, it's had this issue since I got it) but it will sometimes run as if it's just not producing the power it normally does. However, the problem isn't awful (i.e. it's not dead slow, just below what is expected of it).
    Having done numerous VCDS scans over the last couple of weeks I have these two recurring fault codes:
    17963 - Charge Pressure: Maximum Limit Exceeded
    P1555 - 35-10 - - - Intermittent
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 35-10 - - - Intermittent
    One thing to note, is ever since having this car, between gear shifts it makes a rather nice hissing sound, not really like a proper dump valve noise but a hiss nonetheless, I thought this was normal for this type of car (being a turbo) but I've read a lot about how people insist it should be silent on A3s/S3s due to the recirculating valve.
    The reason I really want these codes sorted is I'd like to take my car to one of the reputable tuners on here for a remap, but I want all faults resolved beforehand to get the best out of it.
    Thank you in advance for all helpful replies!
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,087
    17963/P1555 - Boost Pressure Control: Upper Limit Exceeded
    Possible Symptoms
    Reduced power output
    Limp mode
    Possible Causes
    Boost Pressure too High
    Hoses/Pipes incorrect connected, disconnected, blocked or leaking
    Charger Pressure Control defective
    VNT (variable nozzle turbo): nozzles stuck
    Solenoid Valve for Boost Pressure Control (N75) defective
    Possible Solutions
    Check Hoses/Pipes to/between Components
    Check Solenoid Valve for Boost Pressure Control (N75)
    Check / Clean / Replace Charge Pressure Control
    Check / Clean mechanism for variable nozzles
    17705/P1297/004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    Possible Symptoms
    Malfunction Indicator Light (MIL) ON
    Power Loss
    Possible Causes
    Leaking Hoses and/or Pipes between Components
    Boost Pressure Control Valve (N249) faulty
    Diverter Valve faulty
    Throttle Body dirty
    Vacuum leak
    Possible Solutions
    Check Hoses and Pipes between Components
    Check / Replace Boost Pressure Control Valve (N249)
    Check / Replace Diverter Valve
    Check / Clean Throttle Body
    Perform Throttle Body Alignment (TBA)
    Check for Vacuum leak(s) including PCV system
    These are the details from the Ross Tech Wiki, sounds like you could have a boost leak on the car somewhere, have a visual look and if you cant see anything, see if you can get a pressure or smoke test done to see if it can identify where the leaks are.
    Where are you based??
    FJ0372 likes this.
    Jan 2012
    21
    Thank you Nilz, very insightful. That's a lot of possible causes though! I'm based around East London/ Essex.
    Nilz's Avatar
    Apr 2006
    10,087
    There are alot of causes there, but to be honest its worth getting it boost tested if you can as it sounds like alot of the resolutions are linked to this.
  1. vcds fault code
    By lee58uk in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th January 2012, 15:00
  2. VCDS Fault Codes
    By Andy Shipton in forum VCDS (formerly VAG-COM) forum
    Last Post: 24th August 2011, 20:37
  3. Random lack of power...MAF? K&N? What's this?
    By Barbel12 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2010, 18:18
  4. s3 fault codes 17705?what problems this cause?
    By jarvis**turbo** in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2008, 21:10
  5. VCDS Fault codes . . .
    By Olly_K in forum VCDS (formerly VAG-COM) forum
    Last Post: 1st September 2006, 15:29
