Volks AutosBadger5
Results 1 to 8 of 8
    Mar 2013
    14
    Bam bare block same as AGU?
    hi there quick question to confirm weather the bare block of an AGU is same as a bare block BAM I understand the compression ratio is different and Block casting numbers appear to be the same, Also are the cranks both same?
    Reason why is I decided to forge my engine and put an AGU head on, But impossible to find just a head so I bought a hole engine and I thought instead of taking mine out I can still use my s3 while rebuilding AGU bottom end i.e. 83mm pistons, forged rods and bolt on AGU head and then all I got to do is changed cams over and vvt unit from mine?
    All answers would be appreciated.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,542
    All the same.
    Compression ratio is determined by pistons
    Mar 2013
    14
    All the same.
    Thanks karl I didn't see why they would be different as casting numbers are same, cranks all same to? and both forged?
    Thanks dale
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,542
    Yep cranks same across all 1.8ts.
    Only blocks that vary are longitudinal ones, such as the AEB.
    Mar 2013
    14
    Thanks again karl all done here.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,542
    P.s. You dont have to swap cams over to the agu. Only vvt.
    Mar 2013
    14
    Hmm been told different about all this glad I asked now karl life saver! :-) think I need etka at some point lol, And will save me some time and space clogging garage up now lol
    Scullies's Avatar
    Feb 2012
    Dubai
    1,260
    Quote Originally Posted by nailer View Post
    As Karl said, its the same.
    All 1.8t with internal water pump use the same 06A block. ie: 1.8t in A3,S3, some A4,golf gti, bora, and seat range etc etc
    The older block engines like th AEB and older VAG modes used th 058 block with external water pump and intermediate shaft to drive the distributor. I think they stopped using th 058 block with the mk3 golf.
    Even the 2.0 fsi engine uses the same 06* block, it has some slight casting differences. That's why the fsi cank is a straight drop in option to build a stroker motor.
    The tsi motor is a complete new design.
  1. Are AEB pistons the same as AGU?
    By slowcoach3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2013, 19:02
  2. Rebuilt K03s turbo / downpipe / big bore exhaust manifold / remapped ecu AGU
    By beachbuggy in forum For Sale/Wanted - Audi Parts
    Last Post: 16th February 2012, 22:42
  3. Broken rear spring - are BAM rear springs same as AMK rear springs?
    By chris-edin in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th November 2011, 23:13
  4. Any Other Bare Blocks The Same As APY
    By darreng1983 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd October 2010, 19:35
  5. ARP head studs, does the bam block have 10mm or 11mm bolts?
    By Andrew@A.L.D in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2010, 09:52
