AH FabricationsChris Nott
Results 1 to 9 of 9
    Oct 2011
    733
    Any one tried this mod?
    Interesting read, just wondered if anyone has tried it?
    Only for mapped cars
    Fourtitude.com - Wastegate Actuator Spring Mod
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,043
    Adding stiffness to the actuator can potentially cause massive overboost...
    REMAPS: Everything you need to know about remaps....
    ...particularly the bit about adding aftermarket actuators... the load profiles need to be tweaked to suite, the map knows how much boost it needs to meet the load request and by stiffening the actuator you raise its base boost pressure (from 0.5bar to say 1bar) and everything moves up with it except the load the ECU is expecting... this will cause boost spikes and limp mode... potentially worse things too like rod bending torque spikes
    <tuffty/>
    Oct 2011
    733
    Yes i agree with everything your saying.
    i have read the remap thread, a great read.
    But as with everything not being equal i.e old engines and wg being old and worn, old maps and so forth.
    And those of us running generic maps, and unable to get custom mapping till a later date(slippery slope as its put of this forum)
    To be fair the overboosting is covered and an mbc should control this.
    beachbuggy's Avatar
    Surrey
    1,727
    Quote Originally Posted by jezzy View Post
    have a read of Gops thread and how things improved with an uprated actuator.
    Oct 2011
    733
    Quote Originally Posted by beachbuggy View Post
    Hi Dan
    Yes i have read Gops thread.
    Is this not a cheap version of an uprated actuator?
    Im only asking about the springs because i have had the engine out (mani cracked) clutch change which was a disaster(clutch made to wrong spec) and dont fancy stripping everthing back again
    When i first took her out with the new flywheel (f1 lightweight) it went like stink.
    Now it seems slower from low down.
    So i was wondering if anyone had tried this mod and the results
    beachbuggy's Avatar
    Surrey
    1,727
    Actuator can be swapped in 20 mins
    Oct 2011
    733
    Plug and play Dan?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,043
    Same thing applies to an uprated actuator as it does with the pikey spring mod... potential for boost spikes so substitute 'plug and play' for 'easy to swap'... plug an play suggests you swap it and it will just work which is not necessarily the case...
    Gops map was tweaked to dial the new actuator in... its a great mod but needs map tweaks
    <tuffty/>
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,361
    only work on dumb cars like AGU, anything with a map sensor will prob go into limp mode.
  1. Any one recognise this part that i found in the rear footwell !!!
    By GT130 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2008, 20:09
  2. Any one spot this in web news/
    By fallmonk in forum General Chat
    Last Post: 25th February 2008, 18:22
  3. any one had this problem
    By Ballcrusher in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th June 2007, 23:24
  4. any one tried this
    By tommyt2 in forum Tuning
    Last Post: 9th May 2007, 09:15
  5. Dealers? Any one used this one?
    By steeve in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th January 2005, 11:25
