Monster MotorsportBadger5
    TheKoolio's Avatar
    Original Audi Bad Boy
    May 2012
    9
    Oil in Water.... but no smoke.... oil cooler gone?
    Hi
    My facelift model was flashing for oil level the other day so i put more oil in. Checked the coolant expansion tank and saw it was full of a brown like oil. Theres no smoke and my temps arent going all over the place. Someone mentioned my oil cooler going but could someone point out where it is so I can see for any visable damage.....
    Going on what Ive said does it look like oil cooler? I know headgasket is a possibility but as mentioned I have no smoke or other issues. Oil filler cap is black, no mayo like substance.
    If my searching comes to no avail ill get it pressure tested and see what happens
    thanks
    Mar 2013
    Chelmsford , Essex .
    245
    Square block ( about 4" square and 2" thick )sandwiched between oil filter and the cast alloy housing that's bolted to the front if the block , identified by two water pipes going to it
    hope that helps ?
    Baz
    1999 Silver 8L A3 1.8t sport (AGU) currently undergoing rolling modification
    pipercross panel , bosch super 4's , poly bushed front end , yellow dogbone , self refurbed 16" speedlines , ambient lighting.............TBC
    http://www.audi-sport.net/vb/a3-s3-f...ts-thread.html
    TheKoolio's Avatar
    May 2012
    9
    Hi yeah found it alright.... I cant really see it properly without going under but shall i assume that its this part:
    VW GOLF MK4 AUDI A3 TT OIL COOLER + O RING 1.8T 1.9TDI S3 C856 | eBay
    Mar 2013
    245
    Hi , yep that's the one .
    baz
    TheKoolio's Avatar
    May 2012
    9
    Sorry to be a pain, but I found the following two, which of these will do the job?
    AUDI A3 (8L1) Oil Cooler - NRF 31304 | eBay
    AUDI A3 (8L1) Oil Cooler - NRF 31305 | eBay
    Mar 2013
    245
    Mmmm looking at them I can only see a difference in one of the measurements , one being pretty much 90mm square and the other being 90mm x 100mm so ever so slightly rectangular !
    Id say measure yours and go from there
    baz
  1. White smoke and oil in water AUDI A4 1.8 TURBO
    By mark1977 in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th March 2013, 17:30
  2. B5 TDI Water bottle full of oil..
    By Keithsri in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th October 2011, 19:09
  3. a6 2.5 tdi oil in water help!!!
    By amifa in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 23rd May 2011, 13:31
  4. A4 (B5) 1.8T - Blue smoke/oil burn
    By sprint_48 in forum General Technical / How To
    Last Post: 7th November 2010, 20:08
  5. OIL WARNING LIGHT BUT PLENTY IN????
    By veccyj in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th December 2007, 12:07
