Results 1 to 10 of 10
    BÜBENGRÖPEN
    Dec 2008
    Warrington
    742
    Airbag Switch & Boost Feed
    Two completely different questions but better merging than creating two threads...
    1) I'm looking into sorting all my in-car music system and will need to remove the glove-box. Obviously I have had the glove out before but never disconnected the switch for the airbag and this means the glove box kinda gets in the way - is it OK to do this or will it flag up any annoying errors and will this be easily rectified with VAGCOM?
    2) Currently my boost feed for my guage is being taken from the FPR using a no-buzz t-piece. Now I don't know this for definite but it may have been the cause of my MAP sensor problem; are they any other suitable locations to take a feed from without too much effort or is it OK here as long as the length of pipe for the FPR is still kept short as possible?
    Cheers in advance!
    Kristian
    No longer an Audi driver...
    BÜBENGRÖPEN
    Dec 2008
    Warrington
    742
    Anyone?
    Kristian
    Oct 2011
    760
    boost feed from the fpr is a no no
    Which in turn maybe causing your other issues that you posted in the other thread you started.
    Oct 2011
    760
    heres some info on feeding from other locations.
    Fitting an oil pressure / oil temp and boost gauge...
    May 2012
    RETFORD, NOTTS
    1,753
    if you switch the switch to off, then disconnect it, the ecu knows nothing and the light wont go on. Didnt for me anyway.
    in fact, its only a switch, so just unplugging it shouldnt be an issue anyway.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    I didn't even know there was a switch to turn the pass airbag off, now I need to go look for mine!
    learn something new everyday
    May 2012
    RETFORD, NOTTS
    1,753
    Personally i think the passenger airbag is there to be modified. the modification is a switched live under the steering columb and designed to shut up whining women in the passenger seat :D
    (please do not try this at home!)
    BÜBENGRÖPEN
    Dec 2008
    Warrington
    742
    ^^^Hahahaha... love it!
    Quote Originally Posted by Scullies View Post
    It's inside the glovebox mate
    Quote Originally Posted by @udi A3 View Post
    That is a very good idea!!!
    Quote Originally Posted by jezzy View Post
    Cheers dude - and as regards to other issues you could be very true but I do know the car needs a very good service!
    Kristian
    Scullies's Avatar
    Feb 2012
    Dubai
    1,254
    Well I definitely don't have a switch in the glovebox to turn off the airbag.
    I have a 2001 AMK S3, that was imported from Germany to Dubai. Maybe they had different safety specs depending on which country the cars were made for.
    BÜBENGRÖPEN
    Dec 2008
    Warrington
    742
    Possibly... Do you have a passenger airbag located just above the glovebox?
    Kristian
  1. Changing glove box with airbag switch
    By Gazthesparky in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th December 2011, 16:36
  2. Passenger Airbag Switch - retrofit?
    By SimonP in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st February 2008, 16:05
  3. S3 - Audio Switched Live Feed
    By col6821 in forum In-Car Entertainment
    Last Post: 19th June 2006, 21:08
  4. alpine amp bass boost does what?
    By dunk in forum In-Car Entertainment
    Last Post: 26th May 2006, 19:00
  5. Manifold Boost Pressure Switch
    By mtsakmakis in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th December 2004, 20:30
