EM TuningJMB Retrofits
Results 1 to 7 of 7
    Jan 2013
    Somerset
    Boost Pressure Control Valve (N249) : Open Circuit
    Hi All,
    Upon scanning the car, i got this code - and when using a multimeter to check the wiring at the valve end, i got no reading. Tried searching around for suggestions after this but no joy! Can anyone point me in the right direction as to what i can do next?
    Many thanks.
    Jamie
    Scullies's Avatar
    Feb 2012
    Dubai
    1,258
    You should get 12v across the n75 plug wiring. The points might be loose, try checking the power supply a bit further down the harness.
    edit, sorry I can't read
    n249 is different to n75
    have you done the n249 delete?
    JUS3IN's Avatar
    silver sleeper
    Mar 2013
    kent nr maidstone
    694
    what he said and check earths
    1999 apy s3, n249 delete, sai and n112 delete. bbs lm reps, s2000 filter, relentless v3 manifold, relentless downpipe and sports cat, scorpion cat back system, badger 5 v3 tip, bam rocker cover, push in coilpacks, toyosports fmic, amd remapped to 280.3 bhp and 263.9 lb/ft.
    RIP S3dave
    May 2004
    nr Glos
    7,187
    you can drive the outputs via VCDS to check outputs
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
    Jan 2013
    Somerset
    Thanks for your inputs. heres where i am now -
    Got power readings which are fine and done a resistance test on the n249 valve and that seems fine. Next suggestion? Can anyone explain what 'Open Circuit' means? i assumed it was like a broken cable!
    Cheers!
    Also - It has been bypassed, had this code since i bought it, but finally trying to get it fixed
    Scullies's Avatar
    Feb 2012
    Dubai
    1,258
    Have you tried clearing the code? Maybe it was an old fault that's not been cleared.
    Jan 2013
    Somerset
    Yeah cleared it but problem still persists!
  1. S3 Boost Pressure Regulator Valve N75 Open Circuit
    By danderton in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2013, 14:12
  2. Fault code 17608 Boost Pressure Control Valve
    By Coless3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd January 2013, 20:46
  3. boost pressure control valve mechanical malfunction
    By stoneys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2010, 20:01
  4. code 18223 pressure control valve
    By toolnut in forum General Technical / How To
    Last Post: 22nd January 2009, 01:32
  5. Boost pressure control valve
    By imported_SYNAPS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2004, 09:33
