Monster MotorsportChris Nott
    Jun 2013
    Help, Car cutting out.
    Hello,
    Today I changed the rocker cover gasket and now the car cuts out at higher speeds and i have to turn the key to start it agian. All pipes and cables seem to be fine I am stumped, any ideas guys?
    The car is and S3 1.8t.
    Thanks in advance.
    Dave
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    Hi... have you plugged all the solenoids and valves etc back in properly? coil pack wiring loom earth on the top of the cam cover? connected hoses back as they should? checked for spilt hoses now that everything has been disturbed?
    I would also scan for fault codes as there could be some clues there too...
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,059
    Check wiring to the cam/crank sensor, if its when its warm, most likely the crank sensor is duff, or get it on the computer to be certain..
    Jun 2013
    <tuffty/>
    thinking about its the earth cable for the wiring loom it has been put back on the cam cover but the the cover has been spayed lol i best try scraping some of the paint off where it connects
    Jun 2013
    Quote Originally Posted by daveking87 View Post
    Looks like that solved the problem, could anyone explane why?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,021
    Its a required earth for the coil packs.... without it the coil packs will struggle when loaded... have had an engine run like a bag-o-poo on cold start too...
    <tuffty/>
  1. Help Car cut out while driving
    By Mark24a3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th November 2012, 12:48
  2. ESP Light on and Glow Plug Light Flashing - Car Cuts Out! Help!
    By jay786 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th June 2012, 18:39
  3. HELP!!!!! CAR CUTTING OUT HELP!!!!!!!!!!
    By dannyvalley in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th February 2012, 20:20
  4. My cars cut out today and now wont start ive done a scan could anyone help?
    By TDIDAN in forum VCDS (formerly VAG-COM) forum
    Last Post: 19th December 2011, 23:05
  5. Car cut out, won't turn over. Help!
    By DavidW in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th February 2011, 18:51
