Results 1 to 9 of 9
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,156
    VCDS injector fault.
    I know there's probably not a good time for any fault but a week an a half before Inters definitely isn't a good time!
    Anyway, has anyone had this fault before?:
    Ross-Tech says:
    17648/P1240 - Fuel Injector for Cylinder 4 (N33): Open Circuit
    Possible Symptoms
    MIL On
    Poor engine performance
    Possible Causes
    Fuse for injector
    Wiring harness issue
    Failed injector
    Failed ECM
    Possible Solutions
    Inspect fuse for injector
    Inspect wiring to and from injector, see repair manual
    Ohm test injector, replace if needed, see repair manual
    I'm running 1 year old Bosch 550cc injectors so I don't think the injector I the issue. I've swapped it over with cylinder 1 to see if the fault follows.
    I'm guessing wiring. I assume the injector wiring will break down in the same way as the coil pack wiring over time?
    If anyone has seen this before can you give me some advice? Thanks.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Westy's Avatar
    Dec 2008
    17,156
    Now I'm fooked! Blue seal that sits in the fuel rail just dropped into the engine bay
    I've got the inlet mani off but I can't see it. Are these standard seals or do I need to order from Bosch?
    S3 Build Thread
    May 2012
    RETFORD, NOTTS
    1,704
    steal them off another engine sat somewhere in the garage... :D
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,450
    The rubber o-ring on the injector??
    Theyre pretty generic to bosch injectors. Ebay that shizzle
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,056
    Drama queen!...
    Westy's Avatar
    Dec 2008
    17,156
    Found it nestling next to the coolant bottle! Anyway all back together now. Stated it up and no codes yet. I'll check again tomorrow after its done a journey.
    S3 Build Thread
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,450
    Hard to imagine injector wirimg to get damaged, doesnt see the heat the coilpack loom does. Perhaps just a weak connection?
    If you have a multimeter perhaps worth checking resistance across the pins to see if anything is odd.
    Westy's Avatar
    Dec 2008
    17,156
    It's funny you should say this. I prodded and wiggled all the wiring while it was on and there was no issue. I did spot when I swapped the injectors that the connectors inside the adapter plug is well loose and flimsy so could be that. With a bit of luck it's now sorted...
    S3 Build Thread
    Westy's Avatar
    Dec 2008
    17,156
    No error today. I'll keep an eye on it.
    S3 Build Thread
  1. audi a4 injector fault
    By peter donovan in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th July 2013, 01:34
  2. Audi finally acknowledge 2.0tdi 170 injector fault?
    By Richardesty in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22nd February 2012, 19:05
  3. audi a4 injector fault
    By peter donovan in forum General Technical / How To
    Last Post: 19th February 2012, 09:29
  4. VAG reader threw up a injector fault but....
    By JDM82 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd September 2011, 08:11
  5. Diesel injector fault
    By ArdupinanAudi in forum Diesel forum
    Last Post: 13th July 2006, 21:11
