Results 1 to 18 of 18
Like Tree1Likes
  • 1 Post By s33nyboy12
Thread: calling anyone running S3 ronal wheels
    Jun 2013
    could you please poke a tape measure through the wheel and measure the distance from the face of the disc to the inside of the wheel spoke.
    actually i'll open this up for other popular wheels, would be good to get a list going of what 17's should clear 4 pots
    thanks
    Jun 2013
    anyone?
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,014
    Visit 16Klappe's Instagram Channel
    No.
    No-one.
    The offset of a standard Ronal S3 wheel is ET32.
    What calipers are you attempting to fit?
    I quite often say I'm going to do things.
    Then never do them.
    Jun 2013
    Some large brembo 4 pots, slightly larger than LCR ones, so require maximium clearance but want to stick to 17's
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    5,014
    Is that all you know about them?
    If so, nobody can help you
    Then never do them.
    Jun 2013
    I know a lot more about them then that, they are from a bmw 730i have 44/40mm pistons and i will be splitting the 2 halfs and facing 3mm off so they can run on 312x25mm discs, i will be fabricating my own mounting brackets, this i dont need help doing, what i need help with is finding a 17" wheel that will clear them as i require at least 70mm between disc face and inside of spoke. may end up running arount a 25mm spacer for clearence.
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    5,014
    Well thanks. Now that I have extracted this information from you (quite painfully) I can tell you that the stock offset of a 7 series is 24mm.
    So you will need 14mm spacers to fit the calipers if you retain the standard caliper to carrier offset. Which you won't be because you are apparently skimming 3mm off the faces of the calipers.
    Which for somebody of your suggested engineering knowledge shouldn't have been too difficult to work out.
    That said, and all piss taking aside...
    Why are you **** arsing about fitting these calipers? What are you building? And what master cylinder are you using? Why do you think you need 70mm clearance? Have you not thought that these MONSTER calipers will hugely over heat the discs and cause consant pad issues, and constant boiling fluid?
    Going to all that effort and keeping 312mm discs is frankly retarded; and I have no issues in telling you that. Why not just fit LCR Brembos or GT Junior calipers?
    Genuinely intrigued why you are going to all this effort.
    Then never do them.
    Jun 2013
    Well thats just rude, goodbye
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    5,014
    Goodbye.
    Then never do them.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    Quote Originally Posted by W818 View Post
    He is like that but he does also have a point. Unless you're getting the callipers, brackets, and lines all for free there are a lot more easier options for 4 pots that will fit your car and clear standard S3 wheels without spacers.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,393
    Follow Brodster On Twitter Add Brodster on Facebook
    Jesus Jardo.......you've frightened him off. Could of at least said Hello to him....lol Fair point though.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,427
    The standard S3 Ronals have loads of room for big brakes! And you can easily increase the room with the use of wheel spacers, 15mm will fit on the front running factory 225/45 rubber, so plenty of clearance.
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    5,014
    Maybe I was a bit mean. Sorry.
    I just thought his attitude seemed a bit "know it all" on his reply to me asking if he knew any more about the callipers. Which wasn't befitting the nature of the question, which is fairly basic.
    Ho hum.
    Then never do them.
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,366
    Quote Originally Posted by 16Klappe View Post
    dont beat around the bush! If jaardo had spoon fed me this info I'd be happy!
    he should say " thanks pal, great info but do yourself a favour and get some etiquette lessons! Cheers"
    jaardo answered his question and fast, thumbs up from me :-)?
    Sean
    Current: 2013 Audi A3 2.0 tdi s line 8V in black SD nav+ extras, E46 BMW M3, 1971 Volvo p1800, 2014 Ford transit sport 155ps ;-)
    Previous : Focus st 225 stage 1 (265 bhp and too much torque), 2002 audi s3 bam engine completely OEM, 2001 Audi a3 1.8 TQS 221bhp and about 20 other cars, majority civics ek4/ek9 and Bmw / Audi soot chucker's!
    Oct 2011
    759
    hi mate
    I run the gt juniors on 17s superleggeras et is 35 but need 10m spacers so et25
    heres some pics
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,366
    I like them!
    apart from the scuff...... Bet it was the mrs ayy? Lol
    Sean
    jezzy likes this.
    Oct 2011
    759
    pot hole grrrrrrrr.
    But i just had them repainted and i got some of the paint for touch up
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,366
    Least you got touch up paint then, Something different mate and with Audi centre caps gets a big thumbs up from me...... Nice mate
  1. Pic request of anyone running 225/40/18 on 8.5j wheel
    By krisavant in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th August 2013, 21:19
  2. Anyone running 19" wheels on their 8L?
    By sulaiman in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2010, 23:12
  3. Does anyone know what these wheels are called?
    By S4AS in forum General Automotive Chat
    Last Post: 13th November 2009, 16:00
  4. Anyone running 8" wide wheels?
    By HTC in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2006, 12:57
  5. Anyone running a T28, GT28 or GT28RS?
    By excursion in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th April 2004, 19:29
