Badger5Chris Nott
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By Squirrelofdoom
Thread: Found coolant leak - what is this part?
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    538
    Hi guys,
    So I've been losing coolant recently, was worried it was off the recent turbo work I've done, but no worries, that's fine. I found the leak on the right hand side of the head, underneath a 4-way coolant junction that bolts to the head via 2 allen key bolts (where the temp sensor plugs into). I've attached a picture of what I can see.
    I think it is this 4 way junction that is leaking given where you can see the pink coolant on the gearbox below it. However, there is also something I've circled in red which also appear to be wet - but I don't know what it is or if I should be investigating that too.
    So, could someone help out with:
    1) What is the 4 way junction thing that bolts to the head? Does anyone have a part number for this? Do they usually leak when they get a bit old?
    2) What is the other part that appears to be wet? Should I be worried about that?
    Thanks guys!
    Aran
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    part number: 06A 121 132 AP - i paid £11.28 with 8% discount from TPS.
    Feb 2012
    Surrey
    538
    Thanks Karl, guess you've had the same problem as me before then
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    yeh its common for the housings to crack. i couldnt even see my crack till i got it off but knew it had to be that.
    Feb 2012
    Surrey
    538
    Cool, I'll order one today. Thanks mate. Any clue on the other boss off the head which seems like it's weeping?
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,533
    looks oily to me?? in which case would be the rocker cover/half moon seal imo
    Feb 2012
    Surrey
    538
    yeah, probably is. Also, just noticed your sig - hilarious
    Feb 2012
    Surrey
    538
    cool, went to TPS and got one! Thanks mate
    superkarl likes this.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    They usually crack on the molding seam, so seem normal once off....
  1. Replies: 4
    Last Post: 6th February 2011, 19:40
  2. HELP: what is this part number? 8p3 807 434 g 1rr.
    By Lewbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd October 2010, 10:42
  3. what is this part????
    By sherry in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th May 2008, 19:34
  4. what is this part making the noise - pics inside
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th June 2007, 17:02
  5. Audi S3 - What is this part in these photos?
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2006, 11:52
