Volks AutosMonster Motorsport
    May 2012
    RETFORD, NOTTS
    1,753
    fitting petrol clocks to desel car... rpm display
    If coding a petrol cluster into a derv car will the cluster read correct rpm on the petrol dial or need the face swapping?!
    Danio where r u lol
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    187
    I'm here, lol
    You will have to do face swap, but it won't work as original. Even after software coding change on VCDS you will have some incorrect reading. That's why I told you it need messing on it eeprom memory.
    Currently not in the country
    May 2012
    RETFORD, NOTTS
    1,753
    Soooooo...
    If i flash the memory from the original clocks to the new clocks.... nah that wont work for what im trying to do.
    Back to the drawing board :D
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,031
    Quote Originally Posted by Danio View Post
    I'm here, lol
    What else read's incorrectly?
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    187
    Rev will count only till 3000. And if you do wrong coding then your mileage will be counted wrong as well.
    Flashing will give you nothing. But if you put new diesel eeprom then it will work but it must matched numbers 8L0 920 XXX
    ScottD3's Avatar
    Nov 2010
    Plymouth
    15,031
    I thought you could get away with just changing the code to petrol and swapping the faces over.
    Shame its not that easy.
  1. Fitting new clocks from another S3
    By JoeD in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2012, 18:39
  2. Mfsw,anyone fitted one from a later car?
    By PhatOne in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th September 2011, 22:31
  3. Stupid clock in my car. !??!!
    By supanova in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th March 2011, 23:10
  4. Fitting miltech to already mapped car
    By evocos in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th March 2010, 09:04
  5. Petrol in a Diesel Car
    By bkmullin in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2005, 11:31
