Volks AutosEM Tuning
Results 1 to 7 of 7
    Aug 2007
    199
    S3 exhaust backbox rattles
    Hi, My 02 S3 rear back box is rattling a little so will be looking to replace soon.
    I want to stay standard in looks and sound (yeah boring I know) so does anyone know where I could purchase a quality rear exhaust back box please? I haven't tried main dealer just yet as its going to be a bit pricey.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    878
    Add Vex182 on Facebook
    Mine started to rattle and I found that one welds on the tips had broken and the tip was rattling, enough that I could hear it inside the car. Welded it back on and it's all good again.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
    epox's Avatar
    Oct 2012
    Glasgow
    574
    check out the heat sheild, 8 or 10mm nuts tightened mine and rattle went away. ps some are a pain to get tp
    mark
    Aug 2007
    199
    Thanks - will have a look.
    Aug 2007
    199
    For a laugh I just called Audi - they want £480 for a new back box...
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,266
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by Perplexer View Post
    If you are looking for a replacement, then a Milltek is usually the choice to go for in terms of a good quality product and proven results/fitment......if you go for the resonated section then this will keep the OEM sound and won't be to loud. Although personally I'd go for the non-resonated section.
    It's pretty costly for a Milltek though, (more than OEM) so you could always pop to your local exhaust fabricator to see what they can offer. Not to sure on where you're located though?
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Aug 2007
    199
    Quote Originally Posted by kwistof View Post
    Thanks. I'm in Derbyshire.
  1. A3 3.2 V6 (2003) - Aftermarket Exhaust Backbox - CHEAP .. HELP!
    By marwayg in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th September 2011, 23:07
  2. Exhaust/Heatsheild rattle?
    By S3-Oski in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th June 2010, 21:19
  3. Exhaust backbox mounting bracket bolts!
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2010, 12:07
  4. Rear exhaust box rattles when cold
    By Perplexer in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th September 2009, 21:52
  5. Who's had the wet exhaust rattle modification?
    By JaGermanCar in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2003, 10:23
