JMB RetrofitsAH Fabrications
Results 1 to 7 of 7
    Jan 2013
    15
    usual serpentinel belt squeak but not the tensioner!
    On full lock its squeaking a lot. Got the mrs to hold it on full lock while i checked and could see that all the bounce is coming from the power steering pulley. So I've took the belt off (which is new along with tensioner) and checked the pulley for any roughness or friction in the bearings but it seems ok.. The only thing i can see is that there is about 3mm of play pulling the pulley away from the PS pump.. Is that enough for my big squeaks??
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,606
    If there is a 'groaning' noise when you are on full lock its because your power steering fluid level is low... check that first...
    <tuffty/>
    Jan 2013
    15
    already checked, full to the brim, actually a little over full!
    Jan 2013
    15
    its not groaning its classic A3 belt squeak.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,606
    Not sure I know what a 'classic A3 belt squeak' sounds like lol but typically noisy serpentine belts are either due to the tensioner being incorrectly fitted after being removed at some point (there is a bracket that can be incorrectly fitted making the tensioner pitch over), tensioner roller bearing on its way out or the PAS pump itself...
    Obvs you put more load on the belt if you are on lock as the PAS pump is trying harder and noises (as I mentioned earlier) are normally related to low fluid but if yours is fine then tbh its not something I have heard before..
    Got a video maybe?
    <tuffty/>
    BENJAMIN's Avatar
    Mar 2011
    472
    The alternator pulley is faulty, most common to fail on Tdi models. They're a clutched pulley on some models. Order a pulley from Tps/Audi, you'll need the special tool to remove it though, most specialists will have this.
    '09 Lci 335d individual. M-dev stage 2, 360bhp 550ftlb. 'Undercover police edition'
    Vwdan80's Avatar
    Nov 2011
    South east
    100
    +1 on the alternator pulley ^^ changed loads of these
    2002 s3 silver, BAM, lcr Brembos ds2500 pads, Braided hoses, forge 008 dv, stack boost gauge, power flex dog bone bush/wishbone bushes, forge boost hoses, B5 tip, B5 remap, toyo fmic
  1. Drivers Side Footwells Swimming Pool - but not the plenum plugs
    By miniredcooper in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th January 2012, 20:19
  2. S3 Alarm Problem, but not the batteries!
    By silver_mase in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th June 2010, 17:24
  3. Replies: 3
    Last Post: 1st April 2008, 09:28
  4. Disaster! A3 Cam belt failed but not snapped
    By Fandango80 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th June 2007, 09:25
  5. funny joke I heard but not for the sensitive.
    By imported_Yaseen in forum General Chat
    Last Post: 31st July 2005, 16:01
