JMB RetrofitsBadger5
Results 1 to 8 of 8
Thread: New S3 engine
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,631
    New S3 engine
    I know it's nothing for an 8L but I thought I'd share what's totally new about the S3 8V's engine! Quite interesting at the turbo part:
    Engine
    The long-stroke 2.0 TFSI in the Audi S3 is new from the ground up. The only thing it has in common with its predecessor, which was named Engine of the Year in its category five times in a row between 2005 and 2009, is its displacement of 1,984 cc (bore x stroke 82.5 x 92.8 millimeters). The four-cylinder unit delivers a constant 380 Nm of torque to the crankshaft between 1,800 and 5,500 rpm. Rated power at 5,500 rpm is 300PS, and the engine redlines at 6,800 rpm.
    The S3 delivers impressive performance. The sprint from zero to 62mph is completed in 5.1 seconds when equipped with the S tronic transmission (5.4 seconds with the manual transmission), and top speed is electronically governed at 155mph. Combined fuel economy stands at 40.9mpg (manual 40.4mpg). This corresponds to CO2 emissions of 159g/km (162 in the manual version).
    The powerful four-cylinder engine features two balancer shafts rotating at twice the speed of the crankshaft for impressive smoothness, and with the help of an electromechanical sound actuator at the bulkhead this refinement is complemented by a suitably sporting engine note. The exhaust system also includes a sound flap that opens at certain engine speed ranges to give the S3 an even more purposeful soundtrack.
    The 2.0 TFSI boasts groundbreaking solutions in many fields of technology. One of these is the additional use of indirect injection. It supplements the FSI direct petrol injection at part load to reduce consumption and particulate emissions. FSI injection, which works at pressures up to 200 bar, is used when starting and at higher loads.
    On the exhaust side, the Audi valvelift system varies the stroke of the valves in two stages; the camshaft on the intake side can be adjusted steplessly through 30 degrees of crankshaft angle while 60 degrees of adjustment is available on the exhaust side. The compression ratio of 9.3:1 is unusually high for a turbocharged engine.
    The exhaust manifold is integrated into the cylinder head, where it is bathed in coolant. This solution lowers the temperature of the exhaust and accelerates warmup following a cold start, which lowers consumption during the cold-start phase. This concept also has a positive effect on fuel consumption during sporty driving because full-load enrichment is no longer necessary. The large turbocharger is also a new development. It achieves a maximum boost pressure of up to 1.2 bar for even more spontaneous engine response. A high-performance intercooler integrated into the water circuit greatly reduces the temperature of the compressed air and thus increases the amount of air required for combustion.
    With the 2.0 TFSI’s innovative thermal management system, two rotary slide valves consolidated in a single module regulate the flow of coolant. These valves ensure that the engine oil heats up to its operating temperature soon after the vehicle is started; they also maintain the coolant temperature, as per a given driving situation, between 85 and 107 degrees Celsius (185.0° F and 224.6° F). As a result – regardless of load or engine speed – the valves always strike the perfect balance between minimal friction and high thermodynamic efficiency.
    The 2.0 TFSI has been designed specifically for use in the new Audi S3. Pistons with stronger bolts and new rings plus reinforced connecting rods with new mounts transfer the power to the crankshaft. The gray cast iron crankcase has been reinforced at the main bearing seats and the main bearing cover.
    The cylinder head is made of a new, particularly lightweight aluminium-silicon alloy characterized by high strength and temperature resistance.
    An innovative coating on the piston skirts and mounting the balance shafts in roller bearings keep internal friction low. The regulated oil pump only consumes as much energy as is necessary for the current driving situation.
    Despite its complexity and high output, the new 2.0 TFSI weighs just 148 kilograms - more than five kilograms less than the previous engine. Its dimensions are compact: 603 millimetres long, 678 millimetres wide and 664 millimetres high.
    RIP S3dave
    May 2004
    nr Glos
    7,131
    sounds technically impressive
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Scullies's Avatar
    Feb 2012
    Dubai
    1,238
    some nice technical info here to see the difference between fsi and tsi engine.
    http://www.google.co.uk/url?sa=t&rct...j-mqlg&cad=rja
    http://www.volkspage.net/technik/ssp/ssp/SSP_337.pdf
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    Quote Originally Posted by Scullies View Post
    anything like that for the 1.8t?
    Scullies's Avatar
    Feb 2012
    Dubai
    1,238
    heres a tt version, might be some useful engine info
    http://www.volkspage.net/technik/ssp/ssp/SSP_207.pdf
    Jan 2012
    Australia
    47
    Sounds pretty wicked, although I can just see 10 years down the track, all of these fancy bits and pieces being a tuners nightmare.
    dealership: "oh your balancer shafts need replacing? No worries, we have them in stock for 1200 euro. Each."
    Haha. In all honesty though sounds pretty sweet.
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    sounds impressive. Makes it difficult to upgrade the exhaust manifold if its part of the head..
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    mattyboy199's Avatar
    Nov 2005
    UK
    1,688
    If only i could 40mpg out of my 8L, being 300ps with that economy is excellant shame they start @ 30k
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
  1. New Uprated Engine Mounts
    By AndyC in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th October 2011, 12:25
  2. New member, engine bust
    By Rombus in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th July 2010, 23:27
  3. Help, I need a new AMK engine
    By Wingnut Express in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2008, 13:19
  4. Off-topic - Audis new Mid-Engined Roadster
    By Jo Sharp in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th July 2008, 16:36
  5. New S3 engine...any options from other cars?
    By Greggers in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th July 2007, 19:07
