Monster MotorsportBadger5
Results 1 to 8 of 8
Thread: TT Pedals ?
    mattyboy199's Avatar
    Nov 2005
    UK
    1,689
    TT Pedals ?
    Got hold of some TT pedals off ebay but they dont fit ?
    Why is this ?
    Matt
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    Re: TT Pedals ?
    the clutch and break should fit regardless, the accelerator can be LHD / RHD specific, have a look at the two links in the FAQ, they should answer any questions!
    MattS3's Avatar
    Jul 2005
    North Norfolk
    531
    Re: TT Pedals ?
    Stopped buying stuff for cars on e-bay, its just full of [img]/ubbthreads/images/graemlins/swear.gif[/img] quality merchandise most of the time.
    Go to VAG.com and get a proper set that will fit, for less than 30.
    Unless of course they are orignals in which case make sure you put them in boiling hot water first for about 10 mins to help them stretch a little when fitting. Still a bit painful on your finger tips to get them over the pedals, but percivere (sp) and they should go on.
    best of luck
    jpda3's Avatar
    Nov 2004
    Teesside
    117
    Re: TT Pedals ?
    got mine from audi
    leave the acelerator cover on and fit new over the top.
    used a bit of silicone to hold it never moved yet
    other 2 were very easy using the boiling water method as previously mentioned
    robthehungrymonkey's Avatar
    Apr 2004
    Uckfield, Near Brighton
    555
    Re: TT Pedals ?
    [ QUOTE ]
    best of luck
    [/ QUOTE ]
    Boiling water does make it much, much easier. I've bought loads of stuff off ebay and it's always been of good quality. Just check what your buying and ask loads of questions.
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    imported_velcrobix
    Re: TT Pedals ?
    I'm going to get a set from Audi...is there a specific part number i need for a 99' model or is it a case of one set fits all A3's ?
    Jun 2004
    Crowthorne, England
    2,512
    Re: TT Pedals ?
    Have a look in the FAQ at the top of the page, in one of the two threads there is everything you need to know, including the correct part numbers.
    imported_velcrobix
    Re: TT Pedals ?
    thanks mate..found them.
    I'll order them tomorrow.
