AH FabricationsSky Insurance
Results 1 to 8 of 8
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Wiring help with switched live feed.
    I need to find a 12v switched live feed for my AEM Boost gauge.
    It needs to be live on ignition lights and stay live constantly when engine turned over and running.
    Anyone had to locate one before and can point me to one.
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    I should point out that can find loads of switched lives but the go off when engine cranks.
    2001 S3 (AMK)
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,575
    Quote Originally Posted by g60leigh View Post
    I don't think the lives switches off when cranking, just the starter motor pulls all the power! Anyways, I took my power feed for my boost gauge from the ciggy lighter behind the ashtray, and used the dimmer wire as a switch to light up the gauge with the headlights.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,595
    My minor modding thread
    That should help... however is it the end of the world if its cut on crank?... not like you are making much boost urning the engine over ;P
    <tuffty/>
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Quote Originally Posted by ;1906463
    <tuffty/>
    Yeah the AEM gauge calibrates itself.
    So when ignition on and engine off it sweeps and sets its base level.
    Then when engine running it reads normally
    2001 S3 (AMK)
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,595
    In which case you will need to pick it up from something you know doesn't turn off during crank in the fuse box or similar... (as I did for the fuel pump relay for my inline pump in the post I linked too )
    <tuffty/>
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    Thanks Tuffty.
    I will check that one out.
    Just to confirm.
    You picked yours up from the the blue with red stripe coming out of the fuse board?
    2001 S3 (AMK)
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,595
    I picked mine up from the fuel pump feed as this was appropriate for what I was using it for... colour may vary... so ALWAYS check...
    The blue/red wire is the fused side of the fuel pump feed... you could take a (fused) feed from the main ign switched feed which from memory is a large yellow wire with a black stripe BUT!... always check with a volt meter to be sure...
    <tuffty/>
  1. Help with replacing hazard warning switch
    By Stepho in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th April 2008, 20:42
  2. help with rns-e into 8l a3 wiring
    By nick1973 in forum In-Car Entertainment
    Last Post: 11th February 2007, 20:20
  3. S3 - Audio Switched Live Feed
    By col6821 in forum In-Car Entertainment
    Last Post: 19th June 2006, 21:08
  4. Switched live wire?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd October 2004, 10:30
  5. Help with wires to headunit.....(ANDY MAC)????
    By mdoyle69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2004, 17:09
