Like Tree1Likes
  • 1 Post By camscockle20vT
Thread: Over rev and clutch switch
    May 2013
    Channel Islands, Jersey
    82
    Hi guys I have owned my s3 (yr 2000) for 6 months now and living it!
    however I have this annoying over rev problem, I know there are loads of posts on here about this problem and I even found a easy fix guide a couple of weeks ago. However I can't find it again, any links would be great! I am also not very experienced so is this easy enough for me to do?
    Final 2 points, I noticed in service history that the clutch medal had broken, is this causing the problem? Also what switch do I need to buy? Same or newer model.
    sorry and thanks in advance
    camscockle20vT's Avatar
    The stigs ugly brother
    Nov 2010
    1,673
    Hello there, its seems as tho its the same as doing the brake switch, follow this guide http://forums.vwvortex.com/zerothread?id=1158315&page=1 and i dont think you will go too wrong aslong as you have the right tools and can follow basic written instruction. Clutch pedal snapping is common, probably caused the switch to take a wack when it snapped. Hope that helps.
    Scullies's Avatar
    Feb 2012
    Dubai
    1,240
    Following on from this. Is it true an S3 should only start with the clutch pressed in? A mate with a TT says his will only start with the pedal pressed in. Was wondering if this is only TT related or is my switch toast?
    I don't get a fault from it when I do a scan with VCDS.
    Nov 2010
    1,673
    I had a tt quattro and didnt have to depress the clutch for it to start. Think its just us spec and all that jazz.
    May 2013
    82
    Thanks for the help going to give it a go this week, hopefully it gets fixed!
    May 2013
    82
    Quote Originally Posted by camscockle20vT View Post
    Hello there, its seems as tho its the same as doing the brake switch, follow this guide VWVortex.com - DIY - Installing a new brake light switch (without breaking it!) and i dont think you will go too wrong aslong as you have the right tools and can follow basic written instruction. Clutch pedal snapping is common, probably caused the switch to take a wack when it snapped. Hope that helps.
    nice one for this mate!! Worked a dream!
    when taking the switch out it was slightly bent, as in the picture. So must of taken a wack. Anyway no annoying over rev!
  1. Clutch switch changed but car still over revs
    By timski s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2012, 10:12
  2. Clutch switch and cruise control
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2010, 12:47
  3. Revs Rising/ do all S3s have clutch Switch
    By ben_turbo1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th November 2009, 17:03
  4. Clutch Switch over revving - possible quick fix rather than replacement
    By Boro&Beth in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th October 2009, 07:59
  5. Clutch Switch - Revs Hanging on Gear change
    By h3msy in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2004, 11:38
