Sky InsuranceJMB Retrofits
Results 1 to 9 of 9
    Sep 2004
    Glasgow
    919
    Fuel System to Lean - what is the cause?
    Hi
    My car 2001 S3 210bhp.
    I had the yellow engine warning light come up on my dash last week. I ran Vag.com and this was the fault
    Address 01: Engine
    Controller: 8N0 906 018 J
    Component: 1.8L R4/5VT 0004
    Coding: 10710
    Shop #: WSC 01236
    WAUZZZ8LZ11000460 AUZ7Z0A1825361
    1 Fault Found:
    17536 - Fuel Trim; Bank 1 (Mult): System too Lean
    P1128 - 35-00 - -
    Readiness: 0000 0000
    I cleared it and it came back 3 days later.
    The car seems a wee bit lumpy when sitting at say 40 in 4th. I.e its slighly surging. Barely noticable, but as the driver and with the yellow warning light there i notice it.
    So...what i am asking is..
    Does anyone know if this Is a MAF fault or one of the other sensors?
    If it were summer i'd happily tinker around under the bonnet, but being sub zero i'd like to get a spare part and fit it before my fingers fell off [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Cheers in advance
    HTC
    HTC's Avatar
    Jan 2004
    Koh Samui, Thailand
    3,402
    Re: Fuel System to Lean - what is the cause?
    My guess would be either low fuel pressure or a faulty pre cat lambda probe.
    Sep 2004
    Glasgow
    919
    Cheers HTC
    Excuse some daft questions coming up!! I had a clio 1.4 for 9 years prior to this, so everthing cost a fiver to replace and just popped off and popped on! [img]/ubbthreads/images/graemlins/smile.gif[/img]
    Low Fuel Pressure? Would that be the pump on its way out?
    Pre cat Lambda probe - i assume this is an easy replacement?
    Jul 2005
    2,488
    one of the dangers of a faulty MAF is lean fuelling.
    Sep 2004
    Glasgow
    919
    thanks - will clean MAF and then go through the process elimination (nothing to do with my bowels) [img]/ubbthreads/images/graemlins/tongue.gif[/img]
    cheers for the replies guys [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    If its chucking error codes, and it IS the MAF, cleaning it wont help as its too far gone!
    Sep 2004
    Glasgow
    919
    Rich Thanks once again. Will get one ordered ASAP!!
    ...Watching you!
    Earlsfield, London
    5,087
    Im not saying it IS the MAF... But its a likely cause. Best get the codes checked.
    Rich
    Sep 2004
    Glasgow
    919
    sorry must learn to read properly!! Cheers [img]/ubbthreads/images/graemlins/smile.gif[/img]
