Volks AutosMonster Motorsport
Results 1 to 22 of 22
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    audi a3 8l air con relay?
    So my woes continue...... Just got my car back from Halfords and they say my AC system is now all gassed up but still not pumping it through. He said if he pumps it through by hand it works fine (no idea what by hand means) . He said the compressor is working and the fuses are ok and to bring it back in next week to investigate the AC Relay?
    My question is were abouts is the relay and what number is it? Thanks in advance
    Audi A3 1.8 Turbo, Wietec Ultra GT 40mm kit, 3" Full Custom Stainless Steel Exhaust, Custom Code stage 1 remap, 17" RS4 Alloys, Whiteline ARB
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,553
    Check the 30A fuses on top of the battery
    They corrode and give a bad contact...
    If you have the AC on then both fans should be turning at low speed setting... if the fans are not running then the fuse is most likely the culprit... my fuse hadn't blown... was just a bad connection... cleaned it up and all was well again...
    <tuffty/>
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    Would that account for the cold air not coming into the cabin from the AC? Just wondered why the guy at halfords said it was a relay issue? Were is the relay located?
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    While the Halfords guy might be right, never take your car there again please. It's like using Homer Simpson as your lawyer.
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,553
    Don't know off hand... have you scanned for fault codes yet?
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,553
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    Thanks for the links tuffty, that's a lot of good info. Both my fans are working and had a very quick look at the fuse and looks like the picture you posted. Will clean it up over the weekend and try that. Thanks
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    Just thought though if both my fans are working then the fuse must be ok.
    does anyone know the location and number of the air con relay please
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    Also would the pressure switch cause the ac not to flow into the cabin and if so how do I test the pressure switch??
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,553
    Plausible... scan for fault codes though... aircon is the HVAC module in VCDS... if there is an issue with a sensor of something similar there should be a fault code there
    <tuffty/>
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    Will scan it tmr to see if it throws any fault codes.
    Does anyone no the location of the relay box? is it under the dash?
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    Update: Ive run VCDS-lite (only got the free version) and it comes up with this
    Top image i already knew about as ive replaced the sensor but not cleared the codes.
    The second image shows i have a coms error when trying to run the HVac section?
    Managed to pull off the side panel and removed it to see if the relays are behind the fuses but they are not, just a wiring loom.
    So again does anyone know were the A/C relay is located please?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,553
    Bunch of relays under the drivers side dash panel but no idea which one is the aircon one though...
    I had a quick google around about the 'communications errors' and most suggest the cheap ebay leads can be at fault... the fact you can talk to other modules suggest that wiring could be an issue... turn off the aircon (it will still communicate) and any other thing like stereo etc to minimise potential for electrical noise and try HVAC module on its own.....
    Ross Tech have an FAQ on comms issues
    Ross-Tech: FAQ Page 2
    <tuffty/>
    Gizmo20VT's Avatar
    Jun 2012
    289
    Also having problems connecting to my Hvac unit, however on others no problem. Keen to see if the communication error can be resolved.
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    Not to sound like a nob but what dash panel? Already took off the side panel were the fuses are and then took off the 4 hex screws to put out the fuse tray to expose just the wiring looms. I'm at a loss to we're the relays are.
    you mentioned my cons issue might be due to the ac being on and to turn everything off but I did that. I was on the car with the ignition lights on with no blowers on or radio or anything and still didn't work.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,553
    You have to remove the drivers side lower dash section...
    This is a pic of a TT but its pretty much the same procedure and end result...
    Also... found this... its for a Passat it seems but VAG use the same bits across alot of their cars... and the relay number should be the same
    <tuffty/>
    reptor245's Avatar
    Jan 2009
    Torquay
    1,150
    AHA i see now that the panel should drop down.. Will have another stab at it tmr :-)
    Thanks man
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,499
    Quote Originally Posted by reptor245 View Post
    Thanks man
    It doesn't just drop down! lol You need to remove the headlight switch, then there's 4 torx head screws I think, maybe more? Then the whole thing pulls towards you and you can remove it totally.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,553
    There are 3 or 4 screws to undo behind the endpanel (will be obvious when you look) and 3 screws along the underside... one in top of the cubby hole, another the the left of the documents cubby (the one under the steering wheel) and one last one towards the back of the lower dash left had side again.... (T25 torx)
    There are two metal clips one either side of the steering column where the lower dash panel meets the clocks... these need a sharp tug to release the lower dash panel from them (the lower dash panel has plastic lugs that locate into these metal clips...
    You don't have to remove the headlight switch to do this but you will need to detach the wiring plugs of the light switch and unclip the OBD port to fully remove the lower dash panel out of the way... to remove the headlight switch though you push the switch in while its set to 'off' and turn clockwise... headlight buzzer may come on but once done (only turns a little) you should be able to pull the switch out and disconnect the wiring plugs from there... like I say I normally don't bother and just remove them once the panel is loose
    <tuffty/>
    AJC
    AJC's Avatar
    Surrey
    172
    tuffty's advice above should be enough but you may also find some of the pictures at the start of this guide helpful....Replacing Broken Clutch Pedal - How to Guide (with pics)
    I also had the same problem with my fuse and should be the first thing you try/fix.
    Gizmo20VT's Avatar
    Jun 2012
    289
    Thread bump.
    Gizmo20VT's Avatar
    Jun 2012
    289
    Just tested the thread below, changed the latency on the simulator from 16ms - 12ms and can now connect to 08 HVAC
    Auto HVAC - Not able to read - AudiWorld Forums
  1. Audi S3/A3 2.0TFSI Air Con Compressor (N280)
    By TimJK in forum For Sale/Wanted - Audi Parts
    Last Post: 19th January 2012, 21:51
  2. audi q7 air con problem
    By attyq7 in forum Q3, Q5 & Q7 Forum
    Last Post: 19th May 2010, 21:11
  3. Audi 2.0 FSI Sport - Air Con Problem
    By Gogs-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th July 2009, 12:40
  4. AUDI A6 2.0TDI SE 54 REG AIR CON PROBS
    By KJN in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th May 2008, 17:11
  5. Petrol Smell through Air Con! Audi S3
    By Cannonballrun2006 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th June 2007, 15:13
