Volks AutosChris Nott
    Mar 2013
    Slough
    84
    MAF Signal Too High!
    Hi guys had an intermittent fault code pop up. It's the third time it's happened now. Only happens when I'm really booting it!
    I did some logs a while ago posted up on here and it was flowing a lot of air 202g/s in fact. So is this just a faulty MAF?
    car is standard apart from n249 and neuspeed cone.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,578
    Sounds like it tbh... 202gs is remap airflow and if your car is std then this is potentially why the code has popped up...
    <tuffty/>
    Mar 2013
    Slough
    84
    Change it for a new one then?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,578
    If you haven't changed it recently or don't know when it was last changed then its worth doing anyway... I got through 3 genuine ones in 18 months before now... last one I had lasted nearly two years... contrary to popular belief MAF's fail quite regularly but its less noticeable on a std car so most people are blissfully unaware...
    <tuffty/>
    Mar 2013
    Slough
    84
    Ill get a new one from TPS I think! The general consensus on the logs was that the MAF is over reading
  1. Maf signal too high
    By darren t in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2013, 10:11
  2. Replies: 0
    Last Post: 28th March 2013, 10:58
  3. high fuel consumption (act maf readings too high)
    By navicx in forum VCDS (formerly VAG-COM) forum
    Last Post: 2nd September 2012, 17:40
  4. 16502 - Engine Coolant Temp. Sensor (G62): Signal too High
    By dellboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st June 2011, 14:59
  5. MAF signal too high. any ideas?
    By Prawn in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th October 2010, 21:23
