Monster MotorsportVolks Autos
    Jul 2012
    65
    vcds results, possible boost leak?
    so i now own vcds and love it, i just read on hear to check the adaptation mixture in block 32, and also hold the revs at 3000 rpm and the air flow should be 10.00g/s, so off i went and had a look at block 32. it let it run for 5 minuets as i think i accidently reset it, the idle one was showing 0.4% and the other on 0.0% and the same after 10 mins or so. i then tried to hold as best as i could at 3000rpm but the air flow only went to about 9.00 g/s maybe even just below that. my car is a 2003 aum 1.8t a3, 120k miles with no fault codes. how ever when on boost scince i have owned the car you can hear quite a loud ssssssssssssssssss, but like i say no noticeable loss in power however has allways been there and been checked by a couple of people for leaks but none found however never had a smoke test. just information on what to do next really as i want to start modding car but want a healthy engine first. thankyou..
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,086
    Visit 16Klappe's Instagram Channel
    Smoke test.
    I quite often say I'm going to do things.
    Then never do them.
    Scullies's Avatar
    Feb 2012
    Dubai
    1,260
    +1 on smoke test
    make 100% sure there are no leaks before running logs to get an accurate reading. Then you can log your maf reading, 3rd gear pull, foot flat from 2000rpm to the danger zone
  1. S3 AMK Stage 1 Remap Logs - Possible Boost Leak ?
    By sideways steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 4 Weeks Ago, 17:22
  2. Replies: 23
    Last Post: 30th July 2011, 10:47
  3. Possible boost leak?
    By Kroney in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2010, 06:50
  4. Possible Boost leak?
    By SteVR in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd March 2010, 09:41
  5. Possible boost leak
    By Plunky in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st November 2009, 17:13
