Volks AutosChris Nott
Results 1 to 11 of 11
Thread: S3 losing boost
    Feb 2012
    87
    S3 losing boost
    So im pretty sure my S3 is losing boost, it's nowhere near as nippy as it was and there's a hissing noise that wasn't there before. How difficult is it to trace a leak? Are there 5 million places it could happen from?!? :P
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    654
    Probably more than 5 million places dude
    Start to check with the big major bits if the hissing sound is that obvious
    Make sure all the clamps are well tightned. If you don't find anything obvious, you would have to do a boost leak test/smoke test
    Audi S3 AMK
    Relentless-Manifold, Relentless-3" downpipe decat, Forge 007 DV, autobahn88 TIP, K&N Panel filter, EBC yellowstuff brake pads, R32 ARB, Custom column dual gauge pod...waiting for a remap!
    For help/info/pricing on xs manifold and downpipe pm me (not affiliated, nor a reseller trader, just an enthusiast!)
    vivalacoulter's Avatar
    May 2013
    S. Wales
    188
    Follow vivalacoulter On Twitter Add vivalacoulter on Facebook Visit vivalacoulter's Instagram Channel
    Check your turbo inlet/outlet pipes, pipes to the intercoolers ect...
    Feb 2012
    87
    Thanks for the advice guys. It all started when I fitted a badger5 TIP. Think I might have pulled/tweaked something. Are there weak links in and around that area?
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    654
    Check where the tip goes into the turbo.
    And search the forum or google for Badger 5 Tip fitting.
    Here is an example
    80mm TIP Fitting instructions
    Audi S3 AMK
    www.badger5.co.uk
    May 2004
    nr Glos
    6,938
    find someone with a smoke tester.. best £20 you could spend is in finding leaks efficiently and thoroughly
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Feb 2012
    87
    Its the newer version without the turned alloy bit, should be less prone to leaking and to be honest its not that, as the OEM one is back on to eliminate the B5 TIP being a problem, which it wasnt. I'll have a look and see who has a smoke tester in my area Bill, dont fancy a trip up to sunny Scotland do you
    May 2013
    S. Wales
    188
    Sorry to derail slightly...
    Is the v2.2 tip known to leak? I was looking at doing the whole induction kit and was torn between that or the v3.
    Jul 2011
    49
    Add S3_DAVE on Facebook Visit S3_DAVE's Instagram Channel
    V3 all the way one piece so its easier to fit
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Quote Originally Posted by vivalacoulter View Post
    Only way it would leak is if its not fitted properly... have seen this on a few cars that have come in where sealant wasn't properly applied.. there is a fitting guide in the FAQ sticky thread...
    <tuffty/>
    www.badger5.co.uk
    May 2004
    nr Glos
    6,938
    nope. they dont leak.
    not to say any pipe not fitted properly cant leak, but thats user errro 100%
    V3 is simpler if the billet seems daunting (not that it is)
    many 100's of these out there working 100%.
    If in doubt get it installed by someone who is competant.
    Pipes which can be disturbed during removal of your old (likely rotten) tip, will be associated with the oil breather PCV pipes, which are the main ones which rot and split. disturbing them can open up little splits into big arse tears.. Vacuum leaks and boost leaks and malfunctioning pcv systems as a consequence.. Very common on all 1.8t models. Easy to fix however..
    smoke test ftw in finding these leaks also..
    bill@badger5.co.uk
  1. Remapped S3 losing boost high end
    By dgannon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th April 2009, 22:17
  2. Losing boost...
    By Geeman in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th April 2009, 19:15
  3. tdi prob feels like its loseing boost and bad rev
    By stevie_g in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th March 2009, 22:04
  4. S4 losing boost
    By s4mark in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st June 2007, 20:48
  5. S4 losing boost
    By fatarnie in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd August 2003, 22:27
