Sky InsuranceVolks Autos
    epox's Avatar
    Oct 2012
    Glasgow
    481
    ? re injector removal
    hi i am going to replace the filters and seals on the injectors, just one question is the fuel still under pressure when the engine is off?
    if so wath the best way to remove the pressure
    thanks mark
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,451
    It will be under some pressure yes. Get a large thick rag to cover your engine and when you pull the injectors the small amount of fuel will be soaked up.
    Maybe worth removing the fuel pump fuse too, although i cant remember the number. DO NOT cycle the ignition, it will prime the system ready for start up, (hence removing the fuse is a good idea)
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,610
  1. 2.0 TDI PD 16V injector removal tool.
    By madstaff in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th November 2012, 14:56
  2. Injector removal tool
    By Eddieg in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th June 2012, 18:59
  3. Injector removal
    By Sock in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th March 2011, 22:17
  4. 2.5 TDI V6 Injector Removal - Help Please!
    By Magnet in forum Diesel forum
    Last Post: 1st February 2010, 22:41
  5. V6 TDI - Injector Removal Tool & Drain Filter Help !
    By RogerTDI in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th November 2009, 20:25
