EM TuningMonster Motorsport
    Jun 2012
    138
    Misfire under load
    I've put a different ecu on my apy s3,I've modified the wiring slightly to get the ecu to work,it ticks over fine and revs up fine but when you drive the car it gets to about 3500 rpm under load and misfires but if you drive it gently it will rev through fine,does this sound like a coil pack problem as I've read that the coil packs can sometimes play up with a remapped ecu
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,273
    That sounds JUST like a coil pack issue.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Jan 2013
    Derbyshire
    Add Conor.demo7 on Facebook
    I've just had this exact problem.. Although mine was idling rough aswell, plugged in vagcom - No. 2 cylinder was misfiring intermittently.
    Got new spark plugs and coilpacks for piece of mind. £140 in total for four of each.
    Cured the problem!!
    (I have photos of my coilpacks, number two looks like it had seen some heat! I've saved the three good ones incase one goes again)
    If you can access vagcom, I'd recommend it. If not.. If your idle is rough like mine was, try disconnecting the coilpacks leads one by one, listen to the engine behaviour.. Did it change or stay the same? Process of elimination will determine your cause.
    I know what the horrendous 'judder' is like :P
    Jun 2012
    138
    I've now got some red tfsi coil packs on order from awesome gti and some oem push in adapters from Audi so I can use the new coilpacks on the bolt down rocker cover :-)
    Jun 2012
    138
    Quote Originally Posted by Conor.demo7 View Post
    Cured the problem!!
    my idle isn't rough and its really smooth all the way through the revs on part throttle and feels like more power there just when you try to use full throttle it's misfires and pops and bangs like the timing is out,I've driven it today now I've got my new inter cooler on and it seems to be better but seems to be quite laggy now but will see how it feels with new coil packs and plugs,will rev through the misfire now but still a bit of hesitation at about 3500/4000 revs but then once it's above that it seems to start pulling really hard again so got to check everything over make sure all is fine again after have ing a few things disconnected earlier
  1. Misfire/stutter under load/boost. AMK Engine
    By classy in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th November 2012, 18:46
  2. A4 1.9 TDI pd 130 misfire - cough/mis/splutter under load - judder on idle
    By ian-r in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th October 2012, 20:09
  3. Allroad 2.5 TDI Misfire/Judder Under Load
    By tekno_al in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd August 2012, 22:56
  4. Audi B6 A4 1.8T BEX Misfire Under Load
    By Neuk in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th June 2012, 07:10
  5. 1999 S4 - gearbox clunking under load... :(
    By brixo in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th May 2006, 12:33
