AH FabricationsJMB Retrofits
    Sep 2012
    48
    Soft Coding to enable DIS
    Hi guys, I'm after a bit of help regarding the retrofit of a dis cluster.
    its all installed, used vag tacho and vcds and alls well, had it in for a month. However, I've now installed a wiper stalk with rocker switch etc, with new repair wires connecting into the cluster as necessary, but the stalk doesn't activate the dis. I've tried a new stalk, and checked all the wires, was just wondering if there is a coding I need to change to enable the stalk and DIS?
    its a non can bus, full dis, with the orange warning symbols at the top, (I have a bulb out in the 3rd brake light) the middle section is blank but will have the outside temp once connected, and the bottom has miles to empty I think, although the miles only goes to 100 with a full tank, so out by a factor of 5 I think.
    If anyone can help in enabling this dis I'd be most appreciative, spent loads of time and effort in getting it installed, and falling at the last hurdle!
    May 2012
    RETFORD, NOTTS
    1,753
    Yes there is coding needed in the cluster but if miles to empty show its likely the stalk isnt functioning correctly
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Sep 2012
    48
    Well the miles to empty is displaying but neither my 2nd hand stalk, or the brand new replacement change it from the miles to empty view.
    Im after some instructiosn on how to change it?
    If my car is Non can, then it cants display miles to empty or mpg, but can display a trip timer?
    If not il just put my normal dash back in and forget about the dis
    May 2012
    RETFORD, NOTTS
    1,753
    If your car is displaying miles to empty only id assume the stalk or wiring faulty.
    Does the MTE go away when you press the button under the stalk? the two buttons on the end cycle the display.
  1. MK20 ABS Controller - Soft Coding
    By Yohan87 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st May 2013, 20:50
  2. VCDS USER NEER Ellesmere port to enable DIS.
    By turricann in forum VCDS (formerly VAG-COM) forum
    Last Post: 15th April 2012, 00:05
  3. Enable DIS on an A3 with S-Tronic/ DSG gearbox
    By nhowroyd in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th October 2008, 21:22
  4. Soft code won't update
    By dsmclark40v in forum VCDS (formerly VAG-COM) forum
    Last Post: 9th December 2006, 13:51
  5. Can't change SOFT CODE
    By Tinpusher in forum VCDS (formerly VAG-COM) forum
    Last Post: 15th November 2006, 23:31
