AH FabricationsSky Insurance
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By 16Klappe
Thread: S3 cut out with ESP light on
    Jun 2013
    North Lanarkshire
    32
    Hi guys,
    looking for a bit of help / reassurance. Whilst greasing up my sticky back calliper, I noticed that the ESP rod connector was snapped so that needs replaced. I took the car a run thereafter and gave it the obligatory MESSAGE, which was fine ....but.... When I caned it again in first, the ESP light came on, the car then spluttered and cut out. Restarted and it ran but very very rough with the light still on. No other light on in the dash.
    Car is running and esp light is now off but I'm concerned. Any thoughts on if it could just Ben that sensor or something more sinister?
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,313
    Maybe try a vcds scan on it to see if there is an underlying fault. Do you have vcds cable? x
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    Jun 2013
    North Lanarkshire
    32
    A guy at my work has vagcom?
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,313
    Quote Originally Posted by S3 GHO View Post
    I would gt a scan done for peace of mind, if you get stuck for vcds, we have plenty members in Scotland so you wont be stuck. Pm if you need assisstance with vcds. x
    Jun 2013
    North Lanarkshire
    32
    Thanks Sandra, have you heard of a car cutting out with an ESP light before? Seems weird.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,313
    Not that i can remember, one of the boys will probably be along and help you out. x
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    4,899
    Visit 16Klappe's Instagram Channel
    MAAAAAF!
    Sandra likes this.
    I quite often say I'm going to do things.
    Then never do them.
    Jun 2013
    North Lanarkshire
    32
    Maf is a good shout
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    4,899
    Yup.
    Maf unplugged you get the ESP light on, the car should revert to a predefined airflow table based on what the MAP sensor sees, the given RPM and load request of the TB angle combined with throttle pedal. If you have an intermittent MAF fault you *can* suffer misfires due to over fueling and see a flickers of the ESP light.
    Scan it for codes; I bet it says MAF signal too high, or implausible signal.
    Then never do them.
    Jun 2013
    North Lanarkshire
    32
    Good man! Will a vagcom show those faults or does it need to be vcds?
    May 2012
    RETFORD, NOTTS
    1,707
    Vagcom is the old name , VCDS is the new name!
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. Engine cut out, ECS & ESP lights on
    By Hellz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th April 2013, 21:30
  2. Polo 6n2 Cutting out with error codes
    By Nilz in forum Other Brands & Models
    Last Post: 3rd July 2012, 22:10
  3. Polo 6n2 cutting out with error codes
    By Nilz in forum VCDS (formerly VAG-COM) forum
    Last Post: 20th February 2012, 07:40
  4. Problem with esp light on dash...
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd May 2011, 15:34
  5. Cut out at traffic lights and won't start again..please help!!
    By rlc1985 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th August 2010, 08:32
