EM TuningChris Nott
Like Tree2Likes
  • 1 Post By <tuffty/>
Thread: help! timing belt
    Jul 2012
    East Grinstead/ forest row
    99
    help! timing belt
    hi guys, on my s3 is the timing belt meant to be loose when the car is not running?
    in other words does the s3 have a auto tensioner? thanks
    audi s3 8ltodo list - clutchsuper pro all roundmilltek cat backdecatdown pipewellycooler ap coiloversif anyone has any of that for sale let me know! cheers
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    If you meant the run of belt facing to the front of the car then yes... this can go a little slack when you turn the engine off..
    Tensioner is on the other side of the belt run... when the engine is running the rotation takes up the slack between the cam pulley, water pump and crank pulley... tensioner roller and damper takes up the non tensioned side of the belt
    <tuffty/>
    doughty29 likes this.
    Jul 2012
    99
    okay thanks, i thought i had better ask now while my car is off the road and in peices, thanks also i know that you seem to know alot about these cars, is there any special torque driveneeded for getting the drive shafts off? thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    This should help...
    Driveshaft gaiter replacement tutorial
    <tuffty/>
    Jul 2012
    99
    im doing the clutch on om s3 anthing to watch out for? thanks
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,055
    Just the weight of the box, its bloody heavy
  1. Help plz had timing belt and water pump and tensioner done now no power!!!
    By ScottScodude30 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2012, 23:50
  2. HELP!! my audi A4 1.9 TDI awx 130 timing belt has ripped teath off and won't fire :(
    By Chrissy a4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th September 2012, 14:15
  3. HELP how do you tighten the timing belt tensinor
    By hoban81 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th October 2010, 15:40
  4. Timing Belt Question from a newcomer
    By RichbagggA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd October 2003, 17:24
  5. 2.8 Timing Belt or timing Chain ????
    Last Post: 20th October 2003, 07:10
Tags for this Thread
