EM TuningVolks Autos
Results 1 to 8 of 8
    Jun 2013
    Northern Ireland
    14
    Newbie - sticky gears on my A3, please help
    I have just bought a 98 A3 1.8T Sport, car is superb although it can be difficult to get into reverse, 1st & 2nd gears! From 3rd gear up all slip in fine.
    Can anybody please help and advise me as to what could possibly be causing this?
    Thanks in advance
    Boost fiend
    Dec 2008
    Swansea
    207
    Found my old one went like this. Is the pedal on the heavy side, and the biting point high-ish?
    After I changed the clutch to the G60 fly/VR6 clutch assembly it was spot on.
    Found the clutch itself was basically down to the rivets, so proper worn.
    99' A3 1.8T Sport KO3s Custom Code stage 2 - Current
    99' A4 1.8T Quattro Sport 180 - Sold
    97' A3 1.8T Sport KO3s 236 BHP - Sold
    Jun 2013
    Northern Ireland
    14
    Thanks Nick 101 for your reply.
    Do you think it's definitely the clutch? I wouldn't say the bite is high but I do feel a slight vibration when holding clutch pedal in.?!
    After changing your clutch did the stickiness go away?
    What about Gearbox oil, gear selector etc anything like that possible?
    Boost fiend
    Dec 2008
    Swansea
    207
    Well the symptoms you have got are similar to mine, which then went when I changed my clutch/flywheel.
    The vibration through the pedal is probably the dual mass set up on its way out.
    I checked the linkages/selector first which was fine, and changed the oil, which didnt change anything.
    I can't say for sure it's the same with you car, but it does sound similar. Hope this helps.
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,115
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Pretty sure you can get the car on the ramps, give it a little rev and get someone in the know to see if there's any play on the DMF.
    Mine went late last year and made a terrible noise on idle...but with the clutch fully down it went away.
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Jun 2013
    Northern Ireland
    14
    Thanks for your help guys.
    Finally got it sorted I left it with a very knowledgeable mechanic this morning as he was fully booked up til now.
    The problem was just that the linkages needed adjusted under the bonnet.
    10 minutes later all was perfect and still is.
    Makes such a difference and can finally enjoy driving the car.
    Thanks again
    Jun 2013
    10
    hi
    im having same trouble with my recently purchased 99 8l 1.8t reverse is practically impossible to get and even first is a bit notchy, car has 121k on the clock so dont know the clutch condition but no sound difference when ds epressing whilst in neutral.
    hope its just a quick fix!
    Jun 2013
    Northern Ireland
    14
    Try what caused mine. It was a case of adjusting the gear selector cables under the bonnet.
  1. newbie here with a few problems please help
    By s3 toe in forum The Welcome Section
    Last Post: 12th January 2011, 20:58
  2. Newbie what to look for please help.
    By tricky1981 in forum The Welcome Section
    Last Post: 18th June 2009, 21:30
  3. Audi A3 Gear problem! Please Help!
    By m_ozzy_h in forum General Technical / How To
    Last Post: 8th March 2009, 16:25
  4. A3 2.0 FSI Clutch pedal sticky problem - Please HELP!
    By Pom in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th January 2009, 18:35
  5. Please help a newbie
    By s11eps in forum Detailing
    Last Post: 25th April 2006, 09:40
