    Oct 2009
    23
    s3 starting problems
    hi iv just bought a audis s3 with a amk engine and if the car is left stood for a few hours the car wont start 1st time you crank it over but if you turn the ignition off and try crank it again it starts it dosent have any error codes i know the cam chain tensioner is noisy could that cause it ? any help would be apriciated
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    When mine did similar it was the fuel pump dying, eventually it would not start at all, but also check the coolant temp sender..
    Oct 2009
    23
    cheers when it starts it misfires for a few seconds but runs fine when its running
    Mar 2013
    6
    Did you manage to fix this issue if so how ? Thanks
  1. HELP (STARTING PROBLEMS)!!!!
    By harps21k in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2004, 20:13
  2. a4 starting problems
    By lazzaman in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th June 2004, 12:44
  3. 100 with starting problems
    By SaabManIan in forum Classic Audi Forum
    Last Post: 26th April 2004, 03:01
  4. 2.5TDi Starting Problems
    By aj_mackay1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd April 2004, 19:47
  5. 2.5TDi Starting Problems
    By aj_mackay1 in forum General Technical / How To
    Last Post: 22nd April 2004, 12:28
