JMB RetrofitsChris Nott
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By s3dave
Thread: 4wd
    2nd gear sorts em out
    Jan 2013
    preston lancashire
    150
    4wd
    i know these cars say they are 4wd but which wheels actually drive the car the most as i put some new tyres on my car the front ones just before christmas and the rears in january and the rears are on the markers allready on the inside not sure if the cars got a fast road set up but im a bit pissed they need changing allready. could the four wheel allingment be out ? any advice please
    ShaunS3's Avatar
    Yorkshire & Humber Rep.
    Mar 2012
    West Yorkshire
    882
    The S3 is predominantly a FWD car until it senses that there is too much power in the front wheels and begins to lose grip. The Haldex unit then kicks in and transfers a proportion of the power to the back wheels, making it 4WD. The S3 is not a permanent 4WD.
    That's the easiest/simplest way to explain it.
    Jan 2013
    preston lancashire
    150
    that answers part of my question then so is my allingment out ?
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    882
    Quote Originally Posted by jay22s3 View Post
    Without seeing images of the tyre wear, I cannot comment on your alignment. However, if you have only replaced the front tyres recently, the rear ones will obviously reach their wear limit sooner. It would also be a good idea to let us know of your driving style as this may also affect your tyre wear.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Also is it lowered? you may need adjustable tie arms to combat the camber..
    slowcoach3 likes this.
    Jan 2013
    preston lancashire
    150
    the rears where only renewed in januaray and the fronts before that and as i say the rears have worn out allready im not a boy racer but do like to give it some now and then whats the point of having one of these cars if you dont enjoy it
    russwuss's Avatar
    Feb 2013
    458
    Is your car lowered? Sometimes when lowering the S3 it can cause negative camber... Which would cause wear on the inside iirc. There's no adjustment on the rears, unless you buy adjustable tie bars.
    russwuss's Avatar
    Feb 2013
    458
    sorry dave, you beat me to it
    Jan 2013
    preston lancashire
    150
    yes its on 30mm lowering springs
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    882
    Is it wearing on the inside edges of the tyres?
    Jan 2013
    preston lancashire
    150
    cheers for the info guys
    Jan 2013
    preston lancashire
    150
    yes it is
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    882
    yes it is
    In that case, camber will most likely be out causing uneven wear to the inside edge of the tyres.
    As stated above, you will need some adjustable rear tie bars to combat this, which will obviously need to be set up on an alignment system to bring back within tolerance. You may aswell go for a full 4 wheel alignment and make sure both front and rear are spot on.
    Jan 2013
    preston lancashire
    150
    where can i get some adjustable tie bars from ?
    ShaunS3's Avatar
    Mar 2012
    West Yorkshire
    882
    s3dave
  1. Can you convert from front wheel to 4wd??
    By kano in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th March 2004, 06:27
  2. Replies: 0
    Last Post: 29th March 2004, 23:11
  3. Who wants 50/50 4wd? take a look!
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th February 2003, 08:32
  4. Different Types of 4wd explained
    By AL_B in forum General Technical / How To
    Last Post: 17th January 2003, 16:15
  5. A3 4WD Conversion!!
    By Moresauce in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd January 2003, 15:02
