    May 2012
    15
    s3 8l compression issues
    so took my s3 for a run on monday night(spirited driving) as i put my foot down there it seemed a little hesitant so pulled over checked under the bonnet all was fine and idle was perfect so set of again no problems what so ever and on my way home it started misfiring and was struggling badly to get me home.
    ive changed the coilpacks for new ones and the spark plugs also new(i did notice on inspection that the piece that goes around the electrode was loose and close to coming off in cyl 2) and this did nothing.
    i then did a diagnostic test and nothing came up
    and then a compression test (not good)
    1 150
    2 20
    3 150
    4 150
    ive checked the oil level(no change) also changed 3 months ago
    the coolant(no loss but a more darker pink)
    i have had problems with coilpacks recently and it always been cyl 2
    so when i did the diagnostic test i gave it a little rev i noticed smoke and condensation coming up from the oil cap and there was smoke from somewhere else couldnt tell as i was behind the wheel.
    so i have 3 ideas
    cylinder head crack
    headgasket
    bottom end
    its a 225bhp model with a custom code stage 1 remap 255 bhp
    ill probably strip it down tomorrow but i just want peoples opinions before that.
    cheers(sorry about length of post)
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Amk Heads seem to be vulnerable for cracking...
    May 2012
    15
    it the bam engine code mate
    phil miller's Avatar
    Sep 2012
    Devon
    843
    could be anything, burnt valve, weak gasket, cracked head, damage to piston crown, it needs to be stripped and inspected
    ​Wish Rachel would let me have my TDI mk5 back
    May 2012
    15
    Quote Originally Posted by phil miller View Post
    ok mate do you reckon that could be why i keep loosing coilpacks?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,585
    Don't rule out a bent rod either... get cyl 3 to TDC, use a long thin stick or similar and poke it down the plug hole and measure how much it pokes up... then plonk it into cy 2... if its lower its a bent rod...
    <tuffty/>
  1. Compression issue after injector recall
    By nick1 in forum General Automotive Chat
    Last Post: 4th September 2012, 01:14
  2. Revo comments trial issues
    By Kallel in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th November 2003, 15:01
  3. New A3 DIS tiny issue
    By luisdinis in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2003, 08:23
  4. Newbie: Has S3 performance Issue
    By wizard in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2003, 23:07
  5. Bumper Issue
    By tonyrmay in forum The Welcome Section
    Last Post: 23rd July 2003, 13:32
