JMB RetrofitsSky Insurance
    Apr 2013
    Warwickshire
    32
    Misfiring only sometimes agu 1.8t
    On the odd occation my car use to misfire well it's done it's twice but once I turn it off and bk on it used to stop it now it doesn't I start the car an it either runs like **** or it fine , I've checked the coil packs wen it's running an they all fire except number 3 ( if u count number 1 from the cam belt ) I swapped 2and. 3 over to see if it was the coil or plug died , and it was neither the coil from 2 will not spark in 3's place which is weird , I checked to make sure none of the wire have come off the plug or the coil but nothing that I can see no burns tears or nothing , is there a knock sensor or any other sensorsthat can cause this , many thanks chris
    A3 1.8t AUG ,
    k03s, ported exhaust
    Weitec coilovers , SMF lightened an balanced
    Just for now
    " fmic " forge 007p"remap
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,565
    Ignition control module... cyl 3 is a common victim when this goes...
    <tuffty/>
    Apr 2013
    Warwickshire
    32
    <tuffty/>
    thank you for your reply , wat normally causes these to go , where's it located , etc , u jus solved my problem in minutes were as I've been out there swapping this an tht etc lol
    A3 1.8t AUG ,
    Just for now
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,565
    ICM is on the airfilter box... vibrations etc affect them and its common for the internal wiring to break... its not realistically a fixable component as the internals are sealed and potted so normally requires a new ICM unit
    <tuffty/>
    Apr 2013
    Warwickshire
    32
    Thanks mate jus found it an tryed disconnecting it an **** but ur right lol , I'm goin to see if i can get one now before Skool run lol
    A3 1.8t AUG ,
    Just for now
  1. 1.8T AGU MISFIRE ONLY ON CYLINDER 1 !!!!!
    By dandos in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th April 2011, 17:16
  2. TQS on launch strange delay only happens sometimes!
    By Don's A3 TTu in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2011, 14:29
  3. Replies: 6
    Last Post: 10th June 2010, 09:27
  4. Folding mirrors only work sometimes???????
    By qawsed in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th June 2010, 12:52
  5. Replies: 31
    Last Post: 26th February 2010, 13:14
