Badger5Chris Nott
Results 1 to 8 of 8
    RichA3Turbo's Avatar
    ...Watching you!
    Earlsfield, London
    5,087
    Which spark plugs?
    Car wont run properly...firing on 2 or 3 cylinders... think it must be the plugs. They look pretty warn!
    So, what are people using?
    Rich
    Khufu's Avatar
    West coast of Scotland
    5,693
    Re: Which spark plugs?
    Denso uridium thingies. That said, my engine has a helluva lot easier life than yours!
    ...Watching you!
    Earlsfield, London
    5,087
    Was looking at NGK iridium... BKR6EIX
    They should be ok!? Using Beu Ultra X at the moment, but took them out and they are v dirty, and gaps look pretty big. It just wont run on all cylinders...Only since its got cold.
    Rich
    amb276s3's Avatar
    bird spotter
    Sep 2004
    Lincoln UK
    292
    Rich, i recently had melted wires running into the coil packs, may be worth a quick check on them.
    Andy
    ...Watching you!
    Earlsfield, London
    5,087
    Thanks..will take a look!! Pretty sure its the cold weather showing me the plugs have had it!
    Rich
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    [ QUOTE ]
    [/ QUOTE ]
    I too was running Denso Iridium plugs...IK22s.
    I went up one heat range due to the boost and heat of the engine...pretty good they were too...never caused any problems.
    ...Watching you!
    Earlsfield, London
    5,087
    False alarm! Turns out the injector connectors for racelogic were to blame! Had to bypass it for the time being. Looks like a bit of screenwash got in and crystallised on the pin. D'oH!! The A3/S3 scuttle panel is C R A P ! ! ! ! !
    Going to change plugs anyway as when i checked them last night, they didnt look in the best condition!
    Rich
    Feb 2004
    UK
    1,320
    You should run a colder plug with more boost etc.Standard s3 plugs are fine up to 380bhp.
