Badger5Volks Autos
Results 1 to 7 of 7
Thread: Vague Handling
    Stuart35205's Avatar
    Apr 2013
    Telford
    108
    Vague Handling
    Hi all I have the day off tomorrow and feel I need to have a look over the car front to back after a spirited drive I feels dreadful I haven't driven it for a week or so . It has coilovers all be it cheap ones possibly jom , adjustable arb links , new top mounts & bearings , poly bushed wishbones & don't think it's got anything done to the rear , does it require adjustable links on rear it is lowered quite a lot , I will be removing the spacers from the front as wheels hit the arches to much even with stretched tyres but that's another issue! Any ideas & upgrade advice would be appreciated . Cheers Stuart
    2000 A3 1.8t sport AUM
    18 BBS LM , coilovers , strut brace , poly bushed f/end , S3 front discs , S3 rear lights , wrapped roof , face lift front lights , Forge tip , cone filter & heat shield , forge 007 DV , DV relocation kit , n249 bypass , n112 removal, SAI removal , scorpion back box , ECS shallow sump , ECS single mass clutch conversion.
    Apr 2013
    Telford
    108
    I've tried to get some pics of the stance to get som vies aswell ImageUploadedByTapatalk1370895933.040279.jpg
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    Any knocks?
    antiroll bar bushes or rear trailing arm bushes maybe at a guess. I have the original trailing arm bushes on after 110K and i think they need changing (new bushes sitting beside me as i type). It feels a bit nervous - i think knackered trailing arm bushes mean that the toe angle on the rear can change whilst driving which is effectively unwanted rear wheel steering
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Its an A3 Alex so no adjustable bars needed or trailing arm bushes..?
    Alex C's Avatar
    Lizard, Cornwall
    2,604
    lol doh ....
    Alex S3 AMK
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,987
    A3's still have rear beam bushes that could be goosed....
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    Apr 2013
    Telford
    108
    Well I didn't find anything of any con earn but did ind our my wheels are 18x8.5j & ET 30 and only just clear the struts with the spacers on so I have raised the car slightly and made sure its level on all corners now , I think it may be smart to find some poly bushes for the rear and renew as much as poss as its relatively cheap , I would like to possibly fit an arb aswell. Any thoughts
  1. Vibration and vagueness update
    By Oranoco in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th January 2012, 12:02
  2. vague steering, out of ideas??
    Last Post: 20th April 2011, 14:43
  3. Steering started feeling vague after pothole
    By JD09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th May 2010, 12:41
  4. Vague Steering
    By Plunky in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2010, 18:01
  5. door handel
    By cathaloneill in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th February 2006, 09:47
