Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 142
Like Tree53Likes
Thread: K04-064 Tfsi turbo to 1.8 20vt engine
  1. #41
    Jun 2013
    46
    Quote Originally Posted by 16Klappe View Post
    If Bill sponsored the mapping it would take a considerably large chunk of the build cost off....
    How would a K03 conversion differ. The reason I ask is that in three months time I will have access to a free K03 setup from a TFSI when we upgrade my friends Mk5.
    We have already done it to the same Polo!What bhp do you think that gave us?Stock K03 no hybrid...
  3. #42
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,422
    Quote Originally Posted by ;1895994
    Fair point well made... this kind of fitment is popular in the states... guessing the 8P chassis has a little more room in this respect... tight as a gnats chuff on a RHD 8L's...
    <tuffty/>
    Its actually a PITA on the 8P as well.....mine runs a 3" downpipe to the 4" turbo housing,and clearing the master cylinder was the main reason for that choice,and we needed to adapt the kit to fit.
  4. #43
    Jun 2013
    46
    Quote Originally Posted by S3Alex View Post
    The intake temps on the 2.0TFSi do rise a fair bit under heavy sustained acceleration as the stock intercooler is limited if the boost is turned up.
    Some of us with that engine have found intake temps running up to high 40Cs or more,and moving to a bigger inercooler and WMI cures this.
    The LO400 turbo has done very well over in the TFSi world,and turned in some good figures.
    The previous week we made a golf mk5 edition 30 with LO4xx and AEM WMI and we saw at dyno 475 with 60nm torgue!The car has internals and we use one big intercooler kit and one smallest that works parallel and we saw 20 celcious at car with 33 celcious in the dyno room!I think is good...
  5. #44
    16Klappe's Avatar
    Princess Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,083
    Visit 16Klappe's Instagram Channel
    I should think a TFSI K03 on a 1.8t would flow between 270 and 280bhp? As I understand it their flow and power is comparable to a 1.8t K04 with much high EGT safety and more torque?
    I quite often say I'm going to do things.
    Then never do them.
  6. #45
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,422
    Quote Originally Posted by Nick_mk2 View Post
    I'm not surprised.
    The ED30 is a great place to start,and pretty much identical to the S3 8P as you know,and when you uprate the internals you get something very tough indeed.
    Mine turns out a bit over 500bhp and about 650Nm or 480lbs on the current turbo.
    With just the Proalloy intercooler it will run inlet temps around 5C above ambient,with relatively short heatsoak effects in traffic,and to be honest,I haven't checked it with WMI running as the results alone were pretty good.
    The WMI system on mine is also an AEM...really easy to set up and very reliable.
  7. #46
    Jun 2013
    46
    K04-023 as you said has big problem with high EGT with oem manifold!A custom manifold helps out to see lower EGT but still without to make it hyvrid you will not see more than 290-295 bhp!With the K03 of tfsi at polo we saw this number
    The turbo there finished!How to explain it..it wasn't able to give us more power!We tried to give more boost but we saw only high egt and a little torgue more but no more bhp!So we let it there 303 bhp!EGts at this setup was 800-820 celcious the most we saw at full throttle 2nd-3d-4th year!These horsepower was with 1.4 bar boost at peak and 1.2 bar at 7000rpm!So the TFSI turbos are better than 20vts because of their better turbo-manifold flow and cast irons(google translate)
  8. #47
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,422
    I honestly don't know,but I'm sure someone here will!
    One thing I've learnt about here and VAGOC is someone has the right sort of knowledge base,but I can say the K04 when it's maxed out on an S3 8P will run very high EGTs,but I guess you'd expect that from any turbo run to it's limits.....an S3 8P spec K04 or LO400 on a 1.8T should deliver good power and torque.
  9. #48
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    666
    This should be a project for me to do, I have a left hand drive car And I have access to S3 8P turbo and injectors for 2000$, too bad I didnt even sorted a custom map for my current setup
    Audi S3 AMK
    Relentless-Manifold, Relentless-3" downpipe decat, Forge 007 DV, autobahn88 TIP, K&N Panel filter, EBC yellowstuff brake pads, R32 ARB, Custom column dual gauge pod...waiting for a remap!
    For help/info/pricing on xs manifold and downpipe pm me (not affiliated, nor a reseller trader, just an enthusiast!)
  10. #49
    Chlippo's Avatar
    Apr 2010
    Canada/USA/Lebanon
    666
    If possible and for future reference if someone can post details and part numbers about this upgrade it would be awesome. Looks equal or even better compared to a hybrid
    Audi S3 AMK
  11. #50
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,083
    Yeah it kind of makes sense.
    But we can get that quite readily from a standard K04-024 over here. There are 4/5 cars on this forum with a genuine 300bhp.
    It's good graph though, I like that a lot. The power and torque cross over is at a sensible RPM, and the figures look great.
    Then never do them.
  12. #51
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,387
    Power and torque cross at 5252rpm jardo, as they will on every dyno plot in the world ever. If they don't, something is seriously wrong.
    JudderMan likes this.
  13. #52
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,387
    (Given equal scales and torque units)
  14. #53
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,083
    Then never do them.
  15. #54
    beachbuggy's Avatar
    Surrey
    1,746
    It is my pleasure...now we work to use an external wastegate at a K04-064 hybrid!There is no need just we want to see how it works and hear the arrrrr-arrrr Also the s3 now is with internals and loba LO4xxx and we are going to see how much bhp can give!We hope more than 420 bhp
    very nice Nick
    dont want to hijack but i am doing the very same on a 1.8t at the moment, with help from a few people on here. However , I've gone along the route of making up a bespoke adapter that will allow direct fitment of the k03/k04 Tfsi turbo onto the head.
    Plan is to have it fitted and running in the next few weeks possibly but the main issue is the brake mc on our cars, makes fitting it all very tight . We'll be fitting a hybrid k04 on as I've been testing these for a while and hope for similar figures.
    I notice on the picture above that you seem to be running a 023 compressor housing? Again I mocked one up with one as it is considerably smaller and better to use but I fear it hamper flow and really we are looking for and off the shelf setup so welding flanges to manifolds and they like isn't really an option.
    Also this lends its self very nicely to the 1.8t in the A4 as the mounting is all correct orientation.
    m19lte likes this.
  16. #55
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,387
    Very interested to see how that goes for you dan good luk!
  17. #56
    RIP S3dave
    May 2004
    nr Glos
    7,196
    neat to see this..
    rhd clutter of servo etc would need proper investigation regarding clearances
    I can see the appeal for sure.
    good work
    NEW NEW NEW eShop now LIVE>
    www.badger5.biz
    bill@badger5.co.uk
  18. #57
    Jun 2013
    46
    Quote Originally Posted by Chlippo View Post
    Yeah is better in my opinion because with low pressure you can have bhp!
  19. #58
    Jun 2013
    46
    I am sure that if i had a rhd car i would be able to make appropriate downpipe and i don't think that is too difficult to intall it! For bad luck we don't have rhd out here!
  20. #59
    Jun 2013
    46
    Beachbuggy we don't have an A4 to work at and install a K04 for bad luck! The photo you saw was for test in an 20vt because we will fit it to a golf mk2 20vt and we made the appropriate changes to the rear engine mount! So the compressor is not the one that will be fitted!At this week i will post the bhp that we will take from an S3 BAM with internals and a L04xxx! Hope more than 420bhp..
  21. #60
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,283
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    I'd be happy to drive my S3 to Greece for a road trip to see is this works and use my motor as the RHD demo car haha
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
  22. #61
    Jun 2013
    46
    Quote Originally Posted by kwistof View Post
    Yeahh!You leave the car to us and you can go for vacation in one of our beautiful islands or you can stay with us for help!But with 32+ celcious we have now , working is too difficult and the only i have in my head is to go for swimming in the sea!hahaha
    kwistof likes this.
  23. #62
    Apr 2011
    Dublin, Ireland
    621
    Well if it is too warm in Greece. You are more than welcome to come to Ireland to develop a RHD version. I can supply a car, ramp, workshop, accommodation.
    B5 v1 Tip, B5 Exhaust Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket, Devils Own Water Meth Kit, Forge baffled sump.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, R32 ARB's, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear, Vibratechnics Engine Mounts.
  24. #63
    RIP S3dave
    May 2004
    nr Glos
    7,196
    I am surprised the results are comparible on tfsi k03 to old k03 based units.. Are you quoting at the wheel figures of flywheel power on the dynos? Our lupo k03 hybrid (1.8t stylee) will constantly produce 300bhp from 16psi boost at peak power for example.
    www.badger5.biz
    bill@badger5.co.uk
  25. #64
    Jun 2013
    46
    What do you mean with that mate?Sorry but i really don't understand!Can you expain it more?
    This week more work has be done!S3 BAM with internals with L04xx from loba motorsport 430bhp with 61nm!Soon i will have the dyno diagram in my hands!
    Also my friend's Tfsi Golf mk5 edition 30 with L04xx produced 471 bhp with 60nm torgue!There are two remaps!One with WMI kit that produce this 471 bhp and one without WMI that produces 440bhp!One more friend is happy
  26. #65
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,083
    Are your BHP figures at the engine, or at the wheels?
    Do they include transmission losses?
    Then never do them.
  27. #66
    Jun 2013
    46
    wrong post
  28. #67
    Jun 2013
    46
    All the dynos are at the engine not wheel power(whp) and with 4th gear!The dyno we use are very strict!In another dyno may see more power +5-10bhp!
  29. #68
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,789
    The graph above says "Flywheel power" on the left axis. It's just a bit cut off.
    Handling mods++. HTA3582 stroker soon-ish. Hiding parts from the mrs since 2011. Build thread
  30. #69
    Jun 2013
    46
    Quote Originally Posted by Sam_ View Post
    Yeah mate...Flywheel power!
  31. #70
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,542
    jesus christ thats an epic dyno result, huuuge area under curve.
    how do these oem turbos spool so well yet make such high figures???
  32. #71
    RIP S3dave
    May 2004
    nr Glos
    7,196
    looks like Dyno Dynamics rollers in the picture, which measure atw only and factor a % for transmission losses.
    Nice power on a DD roller fo sho.. impressive loba K04.
    Does the loba k04 use the std K04 exhaust manifold? It supports that flow?
    What boost do you have to drive it at to get those figures? Any boost plots available.
    Looks very tasty me likey this a lot
    www.badger5.biz
    bill@badger5.co.uk
  33. #72
    Jun 2013
    46
    Lobas manifold have better flow that OEM!Loba has make some things also to the mani not only to turbo!So you gain a lot with that turbo!This Golf has 2 bar overboost and 1.8bar constant!Yeah this car goes like devil in the road and has power from low rpm until the end!
  34. #73
    beachbuggy's Avatar
    Surrey
    1,746
    Loba 4xx is a complete mutant. They basically take a new k04 tfsi turbo and a ttrs turbo, chop them in half and make one turbo.. Why they do this I'm not sure i assume possibly as the ttrs bearing housing , turbine wheel are different and want fit into the k04 turbine housing, cost is sky high on this unit, but good figures..
  35. #74
    beachbuggy's Avatar
    Surrey
    1,746
    yes it's a standard k04 exhaust manifold.. Maybe ported at the inlet end but other than that, just a clipped turbine wheel
  36. #75
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    This is so interesting and very strange, ill tell you why.. I've been thinking about this for some time, and was just waiting till I get to bills to ask him if this was possible because I wanted to try it! Now today I was thinking about this all day and I hadn't even seen this thread! Now I seen this thread I'm so interested!
  37. #76
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,598
    Quote Originally Posted by Gops View Post
    DO IT!
    My S3 is also available as a test mule! Lol
  38. #77
    16Klappe's Avatar
    Princess Slayer
    Sep 2008
    Basingstoke
    5,083
    I'm currently debating whether to spend the money I was going to spend on a K04 setup on a set of rods, then buying a Black Widow K300 hybrid in September.
    320bhp+, direct fit to K03 cars...Kind of eclipses the TFSI setup for performance to price.
    Then never do them.
  39. #78
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    Well, it'll be some extra cash from current hybrids but I like to be a little different ill just save up as much as I can and see what happens!
  40. #79
    Jun 2013
    46
    We also make our hyvrids we less money but less power than lobas hyvrids! Better than oem k04 but worst than loba's!
  41. #80
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    i appreciate it! but it'll have to be a beach buggy hybrid if I go that route
    Chlippo and kwistof like this.
  1. custom de-cat K04 B7 tfsi
    By spider74 in forum For Sale/Wanted - Audi Parts
    Last Post: 8th April 2013, 11:53
  2. K04 turbo, difference between APY and BAM engines?
    By Dubstep in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th June 2011, 14:07
  3. baffled by a 20vt. engine knock
    By Matt82 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2010, 13:11
  4. New 1.8 TFSi Engine in Price Lists
    By BK1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th October 2006, 21:18
  5. 2.0 TFSI engine sounds like a diesel !!!!!
    By co55ie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th August 2006, 22:33
