Chris NottEM Tuning
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By SoljahofSensi
Thread: Crank Case Vent Valve Hose
    ollie2013uk's Avatar
    Mar 2013
    61
    Hi all,
    Does anybody know the hose part number that connects the crank valve to the turbo inlet pipe?
    I cant seem to find it anywhere!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,576
    Quote Originally Posted by ollie2013uk View Post
    Hi all,
    The plastic one that comes up from the block to the cam cover 3 way hose?
    Part numbers are normally on the parts them selves... VAG are pretty good at that...
    <tuffty/>
    Mar 2013
    61
    Thanks tuffty, the car isn't with me at the minute, I thought I'd just ask. No its the hose that goes straight into the TIP then to the crank breather.
    I'll have a look tomorrow if no one knows.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,576
    No such pipe unless yours has been faffed with... there is a plastic elbow that comes out the top of the oil filter housing... this goes to a rubber t-piece that has a PCV valve for the inlet manifold, the other end connects to a plastic or metal pipe that goes to the 3 way rubber hose coming off the cam cover outlet... the third outlet of this 3-way hose connects to the 'hocky puck' PCV valve before connecting to the TIP... depending which car/year you have there will be slight variances in the hoses etc but the layout is the same regardless...
    This may help...
    https://www.google.co.uk/search?q=1....w=1032&bih=912
    <tuffty/>
    Mar 2013
    61
    This is the pipe i was on about mate:
    Nov 2011
    W. London
    63
    06A 103 817
    just happened to have mine to hand, recently changed mine, forge do a replacement if your that way inclined.
    ollie2013uk likes this.
    Mar 2013
    61
    Thanks, do you have a forge part number or link?
  1. Crankcase vent valve
    By Hanz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th February 2012, 22:28
  2. crank case breather
    By vr6gordy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th December 2010, 19:22
  3. 1.9 TDI crank case pressure (youtube clip)
    By johnmccracken in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th August 2009, 14:39
  4. normal crank case pressure
    Last Post: 4th August 2009, 01:15
  5. Crank case oil seal
    By aldi in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2006, 21:46
