Crank Case Vent Valve Hose
ollie2013uk
Active Member
Norwich
Hi all,
Does anybody know the hose part number that connects the crank valve to the turbo inlet pipe?
I cant seem to find it anywhere!
Hi all,
The plastic one that comes up from the block to the cam cover 3 way hose?
Part numbers are normally on the parts them selves... VAG are pretty good at that...
<tuffty/>
Thanks tuffty, the car isn't with me at the minute, I thought I'd just ask. No its the hose that goes straight into the TIP then to the crank breather.
I'll have a look tomorrow if no one knows.
No such pipe unless yours has been faffed with... there is a plastic elbow that comes out the top of the oil filter housing... this goes to a rubber t-piece that has a PCV valve for the inlet manifold, the other end connects to a plastic or metal pipe that goes to the 3 way rubber hose coming off the cam cover outlet... the third outlet of this 3-way hose connects to the 'hocky puck' PCV valve before connecting to the TIP... depending which car/year you have there will be slight variances in the hoses etc but the layout is the same regardless...
This may help...
https://www.google.co.uk/search?q=1...XO6W10QXk14C4Cg&ved=0CDIQsAQ&biw=1032&bih=912
<tuffty/>
This is the pipe i was on about mate:
06A 103 817
just happened to have mine to hand, recently changed mine, forge do a replacement if your that way inclined.
Reactions: ollie2013uk
