Badger5Sky Insurance
Results 1 to 7 of 7
    Mar 2012
    Maff spade connectors size type?
    I have made a right mess of replacing my maf plug (1J0 973 999 A).
    I can not get the wires out going to have to cut them . Does anybody now what type of spade plugs i have to get .
    boost-addict's Avatar
    Aug 2011
    977
    I cant remeber his name but i know tufty can get plugs. Give him a pm.
    Aug 2011
    977
    Might be badger5 that gets the plugs.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,476
    Plugs and repair leads can be got through the dealers... the plug I got for mine (AMK engine code) was 1J0 973 775 A... not sure of the connectors but I suspect they can be bought from TPS/dealer in the same way as the plug as I know they do some repair kits for wiring (yellow wire IIRC) as he has bought similar to re-wire lambda probes for wideband conversions
    My plug change can be found here
    My minor modding thread
    <tuffty/>
    Oct 2011
    greater mcr
    114
    I've just changed mine bud, there are special tools to do it but I just used a hair clip. There's a c-clip inside the plus which needs to be pulled to one side with a small screw driver, then the hair clip pushes above and below the spade/terminal pushing the tabs down (wait until you hear/feel the 'click'. They just pull out easy then. Its a bit fiddly but just take your time n it'll be fine.
    Mar 2012
    Thanks for your replies . my plug looks as bad as yours was tuffty. I will post up the part numbers when i get them come in handy for some else
    Mar 2012
    Re placement wire as ordered from dealer Part number 000979026E
  1. bulb type/size for courtesy/puddle lights in bottom of the doors??
    By rbailey88 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th January 2013, 23:18
  2. What size/type of screw??
    By Daz4311 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th May 2012, 23:06
  3. Different size spare type, still ok use?
    By MTRL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th March 2012, 16:39
  4. Honda Civic Type-R's - common or what!
    By lewy in forum General Chat
    Last Post: 11th February 2003, 10:46
  5. Different Types of 4wd explained
    By AL_B in forum General Technical / How To
    Last Post: 17th January 2003, 16:15
