Sky InsuranceVolks Autos
    Jun 2012
    138
    Apy engine loom wiring diagrams
    Has anybody got any engine loom wiring diagrams for an apy s3 with and without esp please,I'm just trying to figure out if there's a way to wire in an engine control relay so I can run an esp apy ecu on my car
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Dunno if you can see this but there is an APY ECU diagram in here... called 'a3apyecu.pdf'
    <tuffty/>
    Jun 2012
    138
    <tuffty/>
    No mate can't see it but might be cause I'm on my phone :-( I got another wiring loom with the ecu but it has a couple of extra plugs and at least 1 that's missing and also seems the one for the ecu water temp has got 6 pins :-/ also the main big plug that's hidden in the trunking coming from under the scuttle has 2 extra wires and an extra plug that would be hidden under the scuttle trim which has just 1 wire to it
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Quote Originally Posted by Jonesymk2 View Post
    My bad (long day lol...) didn't post a bloody link...
    https://docs.google.com/folder/d/0B_.../edit?hl=en_GB
    <tuffty/>
    Jun 2012
    138
    <tuffty/>
    Thats cool no worries mate lol cheers for that I will have a proper look tomorrow and see what I can find
    Jun 2012
    138
    Cheers for those diagrams tufty was a load of help :-) I've managed to get the car running nice now with an engine control relay wired in,it runs fine on tickover and revs up fine but one problem is when I try to use full throttle it gets to about 3500 rpm it starts coughing and misfiring but if I use part throttle it will rev straight through so any ideas atall anybody would be a great help :-) it doesn't feel like a boost cut as when I got that before it went into limp mode so maybe thinking fuel or spark plugs being blown out as they're old plugs anyway,feels a lot stronger though even on part throttle so going to get somebody to plug vagcom into it try figure out what's going on :-)
  1. Help needed:- Engine bay wiring loom (BKD)
    By aa_autos in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st February 2012, 23:09
  2. Replies: 0
    Last Post: 4th May 2011, 16:58
  3. Apexi AVC-R wiring on APY engine code S3
    By juhanisalo in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th December 2008, 18:24
  4. Alarm/Door connector wiring diagram?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2005, 22:14
  5. wireing diagram
    By lenin in forum General Technical / How To
    Last Post: 14th September 2004, 17:51
