AH FabricationsEM Tuning
Page 1 of 2 12 LastLast
Results 1 to 40 of 43
Like Tree2Likes
Thread: Quick Wheel Spacer Query.
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,263
    I was under the impression that the reason most people went with 10mm spacers on the front and 15mm spacers on the rear was because the front wheels were already 5mm wider then the rears as standard. Is this true?
    The reason I ask is because I used to have 10\15 spacers on my stock ET32 S3 wheels but I was just following the crowd. I sold these a while back to Dane and have only now started to look at getting some more for my stock ET32 TT wheels as they look pony tucked inside the arches.
    I was looking at getting 15\15 until I remembered that the fronts are supposedly 5mm wider already but If someone can confirm this as a myth I'll get 15\15 instead of 10\15.
    Cheers.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,631
    From what I know westicles, they are slightly wider than the rears, but not sure by how much. That's the info I read anyhow. 10/front 15rears seems to be the best compromise IMO.
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    the bit of paper i have says that the track width of the S3 8L on the front is 1527mm and 1503mm at the rear making the front 24mm wider overall at the front. So 12mm per wheel
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    Keefy's Avatar
    Feb 2009
    Bristol
    123
    I ran 10/15 for a while with OEM RSTTs, but the fronts still appeared to be wider. I've since gone up to 10/20, which IMO looks a little better.
    '01 Facelift S3. CC'd by the Badger
    Westy's Avatar
    Dec 2008
    17,263
    Quote Originally Posted by Alex C View Post
    Interesting. What bit of paper do you have? Something from an alignment system?
    S3 Build Thread
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    Quote Originally Posted by Westy View Post
    CAR blueprints - 1999 Audi S3 (Typ 8L) Hatchback blueprint
    Alex S3 AMK
    Westy's Avatar
    Dec 2008
    17,263
    Legend. Thanks
    S3 Build Thread
    Westy's Avatar
    Dec 2008
    17,263
    I'm now trying to work out the best measurements to get the ET32 wheels to sit as close to the arch as possible and to match front and back.
    I'll get the tape measure on it this weekend.
    S3 Build Thread
    Westy's Avatar
    Dec 2008
    17,263
    Quote Originally Posted by Keefy View Post
    The RSTTs are ET35 AFAIK so my wheels stick out 3mm more each side already. 20mm might be a bit OTT.
    Any pics of your wheels?
    S3 Build Thread
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    i have 8.5J ET25 wheels with 10/20 F/R spacers - admittedly they do stick out a wee bit
    Alex S3 AMK
    Westy's Avatar
    Dec 2008
    17,263
    Are they genuine RSTTs? So your ET on the back is now ET5 lol
    If you could take a few pics for me when you get time id be very grateful. Thanks.
    S3 Build Thread
    Keefy's Avatar
    Feb 2009
    Bristol
    123
    Mine are genuine RSTTs and they're ET33 - 20mm each side seems to sit just right. Can stick up some pics later
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    Alex runs lms.
    You cant compare different width wheels either. Width affects the look as well as offset.
    Rstts are 8 inch wide afaik.
    Just get a dam tape measure out and measure from sidewall to the arch, simple as that.
    Westy's Avatar
    Dec 2008
    17,263
    Alex runs lms.
    Ill do that this weekend fool, said that above. If you had radius bolts with your kit id be buying them.
    S3 Build Thread
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    yeah sorry, they are BBS LM 18" 8.5J ET25 with 10mm spacer on the front and a 20mm spacer on the rear
    To get the same poke on a 7.5J ET32 standard S3 Avus you'd be running 30/40mm F/R
    Alex S3 AMK
    Westy's Avatar
    Dec 2008
    17,263
    Cheers matey.
    I wouldn't be going anywhere near that but i am looking at the possibility of 15/20mm just need to find somewhere that does a kit at a reasonable price.
    S3 Build Thread
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    Cheers matey.
    yep, the only reason i have spacer up front is for the brakes and then i was left with making the rears stick out so they looked similar to the front - hence the 20s on the rear
    Alex S3 AMK
    Oct 2012
    South Africa
    268
    Im running 25mm adapters upfront and 30mm adapters in the rear on 42 offset wheels, ill be changing my rears soon to a 40mm adapter. The front sits way more out than the rears.
    Heres a pic to give you an idea...
    Alex C likes this.
    Westy's Avatar
    Dec 2008
    17,263
    That looks mint Sidey. My car is only lowered 35mm so I'm a bit worried that an excessively spaced 17" wheel might look odd.
    S3 Build Thread
    May 2010
    Bedford
    2,877
    That does look pretty sexy
    Cactus green 8L S3 - B5 TIP + Jetex, Revised 007p, R32 rear ARB, AP Coilovers, Compbrake rear arms, Full Powerflexed dogbone.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,442
    wheels are same width and offset, track or body width is makes the difference... 10mm on ET33 OEM RSTT's are perfect for the front but I have 15mm on the rear and personally reckon 20mm is required to 'fill the arches' in the same way the front is... if I get a chance I'll measure the track width front and rear and see if there is a difference... I suspect though its just the body width being wider at the back thats the issue
    <tuffty/>
    kelk11's Avatar
    Feb 2009
    102
    not the greatest of pics but you get the idea, 15mm front and 20mm rear bought from here and been on 12 months with no issues http://www.jjcraceandrally.com
    Westy's Avatar
    Dec 2008
    17,263
    Quote Originally Posted by kelk11 View Post
    Hmm this looks about right. I'll get measuring but I think I might give 15/20 a go.
    S3 Build Thread
    vrbob's Avatar
    Jun 2007
    Southampton
    2,361
    I have the same wheels and run the same width spacers and yeah i think thats just about right.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    Westy's Avatar
    Dec 2008
    17,263
    Ok had a quick measure up and I'm going to go for 15/20:
    Excuse the filthy car!
    Front:
    Rear:
    S3 Build Thread
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    Do you not think you should prioritise some new trainers???
    16Klappe likes this.
  28. #27
    Westy's Avatar
    Dec 2008
    17,263
    Dude those retro Puma Pele's are my oily car trainers
    S3 Build Thread
  29. #28
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    looks about 12mm front to back
    Alex S3 AMK
  30. #29
    Westy's Avatar
    Dec 2008
    17,263
    I was actually thinking 12mm spacers for the front and 20mm rear.
    S3 Build Thread
  31. #30
    May 2010
    Bedford
    2,877
    Have fun finding cheap 12s just go 15
  32. #31
    Westy's Avatar
    Dec 2008
    17,263
    Quote Originally Posted by Jason.s View Post
    You're correct. Cheapest with bolts are £55.
    S3 Build Thread
  33. #32
    Westy's Avatar
    Dec 2008
    17,263
    Right, going to order 15/20 right now. Can some please confirm to me the bolt head type for OEM S3/TT wheels please. Radius or Tapered? Ta
    S3 Build Thread
  34. #33
    Apr 2011
    Dublin, Ireland
    610
    Where are you ordering from Westy.
    B5 v1 Tip, B5 Exhaust Manifold, Beach Buggy Hybrid, Pipewerx D.P and cat bypass, Miltek resonated cat back, AH Fabs v2 Intercooler, S2000 Filter, 83mm 9.5:1 CP Pistons, Brute Rods, Bosch 550cc Injectors, Oil Catch can, N249 delete, B5 Phenolic Gasket, Devils Own Water Meth Kit, Forge baffled sump.
    H&R Springs, Koni FSD Shocks, s3dave's rear tie bars, R32 ARB's, LCR Brembo's, 18" ttrs alloys, replaced all suspension bushes, 15/20mm spacers front/rear.
  35. #34
    Westy's Avatar
    Dec 2008
    17,263
    Quote Originally Posted by IrishDave View Post
    JJC Race and Rally as posted above. Seem to be the cheapest around but a lot of people have vouched for their quality.
    S3 Build Thread
  36. #35
    Apr 2011
    Dublin, Ireland
    610
    Pretty good prices there. Think I might finally get some myself. Was never willing to pay £100+ for spacers.
  37. #36
    Westy's Avatar
    Dec 2008
    17,263
    I used to have some but sold them to fund PCD adapters for my S4 wheels. When I sold the S4s and PCDs I never got round to buying more spacers. As luck has it I won £82 last night on a work lottery bonus ball thing we do so that'll pay for them.
    S3 Build Thread
  38. #37
    Westy's Avatar
    Dec 2008
    17,263
    Anyone?
    S3 Build Thread
  39. #38
    16Klappe's Avatar
    Certified S3 Slayer
    Crazy Closet Champion, Curveball Champion, Ping Champion, Snakeman Steve Champion, UFO Shoot Out Champion, Typing Test Champion, Smack the Rabbit Champion, Rabbit Hunter Champion, Mosquito Kill Champion, Mini KickUps Champion, KickUps Champion, Disc Dash Champion
    Sep 2008
    Basingstoke
    5,010
    Visit 16Klappe's Instagram Channel
    Conical seat for Audis.
    I accept no responsibility if it is wrong, but I did go to my shed and check my originals for you. So it must be right.
    I quite often say I'm going to do things.
    Then never do them.
  40. #39
    Westy's Avatar
    Dec 2008
    17,263
    Quote Originally Posted by 16Klappe View Post
    Cheers Jardo but is conical a radius or a tapered head? Radius I'm guessing.
    S3 Build Thread
  41. #40
    16Klappe's Avatar
    Certified S3 Slayer
    Sep 2008
    Basingstoke
    5,010
    Yeah, radius type. Sorry, wasn't really clear then.
    Would be worth whipping out out and checking before ordering?
    Then never do them.
  1. quick wheel spacer question
    By Irish EK in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 25th October 2012, 10:09
  2. Me again!!! wheel spacers
    By pinkys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th December 2004, 20:07
  3. Wheel spacers
    By SubaruSTi in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th July 2004, 13:43
  4. What size of wheel spacers?
    By Grant in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2004, 21:22
  5. wheel spacers on the s3 ??????
    By tvr1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th September 2003, 00:16
