    Adam P's Avatar
    May 2012
    Southampton
    395
    Quick Decat Question for custom exhaust setup
    Hi guys,
    I'm currently running a custom long life cat back exhaust system on my 2001 s3 8l. The car has had the usuall stage 1 upgrades, tip, filter, stage 1 map etc. I have got myself a decat from another forum member which when lined up underneath the car seems to fit. The issue i have is that the standard cat on the car has a lambda sensor, the decat has a hole for this but is blanked off. Basically i want to avoid any fault lights from coming up on the dash. My current lambda is well and truly stuck in the standard cat even after heating up it will not budge. Whats the best way around this issue?
    Has anyone else had this issue or know where i can find the answers, i have used Google search and search on here but cant seem to find much. My engine is the 210 bhp from factory model not sure of the code but hopefully someone out there can help and advise me?
    Thanks in advance.
    Adam P
    2001 Audi S3 8L Ming Blue - Rebuild Complete
    Nov 2012
    Kent
    459
    Add Tim_Attard on Facebook
    if you cant get it out im guessing your have to buy a new one but there not cheap iirc, i spent a sloid 5hrs trying to get the 2 out of mine, you can get a open socket which might help i had a spanner and soaked it in PB Blaster or the like
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/187166-tims-max-power-a3.html
    Quote Originally Posted by 16Klappe View Post
    Don't listen to him Tim, You're my hero, I'm proud of you.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,559
    post cat lambda is a narrow band one thats the cheaper of the two... you can prob buy a second hand one if push comes to shove but it needs to be electrically connected else adaption won't work and you will have running issues...
    The probe can also be mapped out if need be...
    <tuffty/>
    Adam P's Avatar
    May 2012
    Southampton
    395
    Thanks for the quick responses guys really appreciate it. Looks like i will try and source another second hand lambda then and get her up on the ramps again. Trying to get the car all up-together for gti international.
    So i am likely to see a fault light appear once the decat is installed and the replacement lambda is connected up?
  1. Quick question on custom exhaust systems
    By Metro in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st March 2012, 23:24
  2. Quick question for anyone with a new 2009 A3
    By h5djr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th October 2011, 23:26
  3. really quick question for aftermarket 8p install
    By cenci in forum In-Car Entertainment
    Last Post: 15th May 2007, 12:56
  4. Quick question for facelift A3/S3 guys...
    By silver75 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th April 2007, 18:25
  5. Quick tyre size question for RS4 B5 alloys.
    By Dan Gliballs in forum General Chat
    Last Post: 6th November 2006, 07:34
