Sky InsuranceVolks Autos
    TDI
    TDI's Avatar
    Oct 2003
    Milton Keynes
    294
    Coil sign stays on dash after starting the car.
    Does that mean they glow plugs need replacing, and are they easy to do yourself or should I get a local garage to do them?
    Cheers [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    Re: Coil sign stays on dash after starting the car.
    the coil sign is a MIL lamp, check you brake lights (and the rest) are working (the switch on the pedal can fail) if all the lights are working you need to get your fault codes read
    TDI
    TDI's Avatar
    Oct 2003
    Milton Keynes
    294
    Cheers peteTDI, will do
