Badger5AH Fabrications
Results 1 to 21 of 21
Like Tree1Likes
  • 1 Post By jonno123
Thread: Max bhp for standard fuel pump on A3 8L
    Mar 2012
    96
    Hi all
    ive now got my gt28 71r fitted and before i waste my time mapping the car on the rolling road
    but whats the max bhp i can go on my standerd fuel pump ?
    i have searched asn and google cant find a answer
    its a a3 8l agu 1.8t
    can i fit a s3 pump will it fit ?
    thanks
    John
    Jun 2012
    Essex
    211
    Chances are, the car has covered a fair few miles. The original pump will be knakered. If you've gone to the extent of fitting a gt28 to the car a new pump will be a definite before its mapped.
    When I eventually get round to fitting a bigger turbo to mine, a new pump will be high up on the list to replace aswell. Don't want to drive all that way, waste niki or bills time to find out full potential can't be reached because I've cut corners
    Mar 2012
    96
    if i get a new one will it flow enought
    i work on a rolling road so i can map it myself , so wont be wasting time or money if it dont flow enought just want to no if i need to upgrade or just fit a new one
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    As already said these pumps have done some work already and I have seen loads starting to fail... we get it all the time at Bill's....
    I believe Prawn uses an S3 or LCR pump as these are rated higher than the std A3 one... A new S3/LCR pump should fuel enough for hybrid power typically but seeing as the GT2871 can go to 360hp I would personally I would fit an inline pump to compliment the intank... either way I would change the current intank regardless
    <tuffty/>
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,319
    Stock lcr pump here, a3 one couldn't fuel 230bhp after 150k miles and ran lean.
    Lcr pump going strong currently, but if I'm honest I think I'm on borrowed time.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,520
    aren't 4WD pumps like the s3 different to FWD drive pumps like the LCR???
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,264
    You'll be looking at an inline soonish then?!
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    LCR pump is rated the same as the S3 (4bar)... just come is a different fitment as the LCR doesn't have the same fuel tank setup
    <tuffty/>
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,319
    Quote Originally Posted by Westy View Post
    I was given a walbro 255 in tank pump in a deal with Ben.
    I've heard about issues with pickup at low fuel levels when fitted wrongly, but I've also heard of people getting really decent results when fitted correctly, so as it was free, that'll be my first port of call!
    Mar 2012
    96
    Prawn were can i get a lcr pump ? What do i have to do to make it fit ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    LCR pump from TPS or a SEAT dealer...
    <tuffty/>
    boost-addict's Avatar
    Aug 2011
    977
    will a audi a4 pump match across. the sport one is 4bar might be cheaper then a s3 price tagged pump
    Mar 2012
    96
    any one know have a fitting guide for a 004 motorsport in line pump please , i think ill just fit one of them
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,520
    Quote Originally Posted by jonno123 View Post
    if a stock intank wont fuel enough for 230hp, how the hell is it going to feed an inline fueling for 350?
    why ask for advice then ignore it.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Healthy std intank pump will act as a lift pump and should be fine to feed an inline pump... the issue with a std pump is it can't maintain the required fuel pressure at the required flow level for the hp expectations ... at the lower pressures required to feed an inline pump then it should keep up...
    Fitting an inline pump is not a fix for a failing intank though... if the intank is known to be failing or just old then replace this regardless...
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    ...ideally you would use a swirl pot... and if buying a new intank its worth upgrading to a more capable one... Bill has a suppliers of pumps he has been using for Ibizas as pretty much all he has seen recently have tired pumps... they seem particularly rubbish..
    <tuffty/>
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,634
    I replaced mine because for good measure before it gets mapped, just to eliminate any problems. That's what you should be doing mate. Eliminate as many problems as you can before its mapped, otherwise they'll come back and bite you in the ass cheek!
    Westy's Avatar
    Dec 2008
    17,264
    You lot have now got me thinking about an upgrade. I fitted a new in tank S3 pump last year but I have no idea how long it'll last on my current setup.
    S3 Build Thread
    StaceyS3's Avatar
    Dec 2010
    Maldon, Essex
    2,088
    Would have thought would be alright for a good fair few years mate as still running 3 bar iirc?
    Theres kits and old stage 2 maps out there like the mtm that run 4 bar and bigger injectors and these seem to last quite a few years although i suspect most of them out there are struggling to provide the correct amount of fuel now with there owners not having a clue car could be running very lean
    Power & Torque 335bhp 285ftlb
    0-60 4.64 1/4 mile 13.02
    My GTX3071r Build Thread
    http://www.audi-sport.net/vb/a3-s3-f...ld-thread.html
    Mar 2012
    96
    sorry i dint make myself clear , i will fit a uprated in tank pump , and fit a 044 motorsport pump wich will flow for about 700 bhp , im only looking to run 280 -300 max , you cant use that much fwd anyway
    superkarl likes this.
    Mar 2012
    96
    I have just spoken to fse glenco
    they can supply a in tank pump that will flow 318 LPH thet should be good for 500 bhp , but i will add a in-line pump on a switch try it and if no good run both , (im only doing this too see if it can be done with just a in tank , as this would save people £££££ )
  1. Max power on standard fuel pump
    By jamie226bhp in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th July 2011, 10:27
  2. Which injectors and fuel pump for 380 bhp
    By Paul_S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2010, 19:32
  3. Upgraded fuel pump internals for 2.0 TFSi
    By TheWusMan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th February 2008, 10:48
  4. standard bhp for my car?!
    By howdy quattro in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th December 2007, 12:25
  5. Replies: 4
    Last Post: 10th April 2007, 14:32
