Is this a normal S3 log?
stuart_tate41
Slough
Hey guys ever since I bought the car I've felt it was a little slow, but I've put that done to coming from a 270bhp 320ftlb modified car to an unmodified 225bhp.
Does this log look normal to you for a standard BAM S3?
195g/s if a realistic maf sensor is healthy - way more than a std 225 would be flowing..
thats enough airflow for 243bhp
log block 031 and 115 also
Interesting! seems to drive unlike my previous mapped car the boost seems to come in a lot harder than I would expect. I had worked it out to 243 but I thought that was optimistic!
Shall I log 002,031 and 115 together in a 3rd gear pull?
Only difference from the 1st log is now I have done the N249 delete (Which should affect G/S should it? )
i suspect either a Really good motor or an over reading maf..
boost requests pretty std as is fueling (lean as std)
Sounds good! I might try another MAF will a MK4 R32 by the same MAF? I think they are both 80mm?
i used to log 191g/s consistently on stock map.
so you can rest assured that its running well.
thing is rest assured you say...
not 100% that
I have seen a few times high apparent g/s but not a real g/s when equating to actual power measured.
It could be that good tho, seen that also.
narrowband maf on wideband car reads higher, but not real g/s
Going to try and borrow a MAF and try again. Just want to get it all sorted before I get a remap :)
671
10
698
839
11
875
