Sky InsuranceEM Tuning
Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By Scullies
  • 1 Post By superkarl
Thread: Alternatives to methanol
    Scullies's Avatar
    Feb 2012
    Dubai
    1,208
    Well meth seems pretty difficult to find around these parts of the world. They guys who sell it don't seem to carry stock.
    so I have been interwebbing and seems that a few people use ethyl alcohol (rubbing alcohol) as an alternative to meth.
    now the ethyl alcohol I can get its 70% alcohol, the other 30% seems to be a mix of water and meth to poison the ethyl alcohol so you can't drink it.
    Has anyone here ever used ethyl alcohol? Do you think it's safe to use with some distiller water?
    these guys say ethanol has more bang per unit than meth does
    What Type Of Fluids Can I Use With My Water Methanol Injection System
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,455
    Ethanol is what is in E85 pump fuel as used in the US. hence the E.
    i suppose theres no reason why not. But im no chemist
    ethanol has the same RON rating as meth.
    Scullies's Avatar
    Feb 2012
    Dubai
    1,208
    But im no chemist.
    Thats probably a good thing
    Dan-Jnr's Avatar
    Jun 2011
    Manchester
    527
    Watch Breaking Bad, might get some pointers from that :P
    2007 - Imola Yellow- Audi S3 - 305
    [8L BLOG] [8P BLOG]
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,158
    Interesting thread. I've got a meth man quite close to me so not a problem plus I've made 25 litres last over a year due to hardly driving the car.
    I'll keep an eye on this thread though.
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    problem with ethanol, and you may already know that the yanks running E85 have twice the fuel system setups, is that it produces less energy per unit than conventional fuel, so requires more of it, hence why when you convert your car to run on ethanol you need much bigger injectors, 1000cc in place of 630cc for example.
    i dont know how this will effect things if you're just injecting a mist WMI style, probably not very much. But it might affect things if you start to use more and more of it as an additive to conventional petrol.
    based on the RON numbers alone though, it should offer the same octane benefits as methanol. and probably the same cooling effects when mixed with water.
    Scullies likes this.
    Buzzer's Avatar
    Apr 2011
    Dublin
    410
    The major down fall with ethanol is when it's concentrated it eats away at pipes and hoses.
  1. Phatnoise / Alternator Whine
    By clcollins in forum In-Car Entertainment
    Last Post: 6th July 2007, 10:35
  2. No A3 Hayne's Manual - is VW a good alternative?
    By koonl in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2004, 15:53
  3. High Flow Cat Miltek Alternative
    By RAPS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th March 2004, 17:00
  4. AVS oil is there an alternative
    By Banwell in forum Tuning
    Last Post: 1st September 2003, 11:19
  5. Serial Port Tuning Alternatives
    By Dylarolla in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2003, 08:49
