Badger5Monster Motorsport
Results 1 to 24 of 24
    Jan 2013
    Derbyshire
    Add Conor.demo7 on Facebook
    Audi S3 recent faults, anyone got advice?
    Hello, I have finally joined the S3 8L gang after wanting one for so long.
    I am extremely pleased with the car so far during my ownership, but have recently encountered a few faults, one of which has just occurred which is rather alarming.
    Current faults are;
    • Intermittent Cooling Fans - Should these run all the time, when stopped or when the engine reaches a certain temp. This has caused one temperature overheat warning so far, when I was outside talking to my mates with the car on idle.
    • Brake Squeal upon low speed 'feathering', it has Mov'It front brakes and new callipers/pads/discs on the rear. (I have been told that filing the pads lightly and putting a leading edge on the pads could solve this)
    • The new alarming fault - It seems that the car is loosing power, the power seems to drop off for a moment or it feels as if the car is juddering.
    • Drivers side window doesn't wind down, no sound of the motor attempting it - When pushed in the 'up' position, the motor is activated, but then senses it is already at the top, and stops.
    The car has been MTM tuned prior to my ownership, I thought it may be turbo related when I first noticed it on 'boost', but now I have realised that it even does it at low RPM in first, etc..
    Any assistance would be appreciated folks, thanks!
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,458
    Welcome to audi-sport.net. Where are you located? Any pics of the car? The guys will be along shortly, in the meantime, have a read at the faqs threads, there is a lot of good info in there. Enjoy the forum. x
    Jan 2013
    Derbyshire
    Thank you Sandra!
    I will try to get some uploaded, only had it since last Monday.
    I'll add my details into my signature.
    Hope to see some of you in the near future!
    I am currently looking for a VagCom unit, looking for a genuine one as I like the idea of all the functions.
    Jun 2011
    Great Melton Norfolk
    1,349
    Pm Nigel (NHN) on here ,he sells vcds cables.
    Jan 2013
    Derbyshire
    Thank you gen.heinz, I will do.
    To connect to my 2002 S3, will I need the VagCom unit, plus this VCDS cable?
    Thanks.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,458
    Quote Originally Posted by Conor.demo7 View Post
    Thank you Sandra!
    For local meets with other members, link below. for vcds cable contact NHN,he is a site sponsor and supplies these. x
    Smaller (Local) Events
    Jun 2011
    1,349
    Just need licensed cable and download software/updates free.
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Hi
    Welcome to the 'money pit'.
    For all of your problems I think google is your friend ( https://www.google.co.uk/search?q=si...rum-8l-chassis ) if you use this google link you can type your search after the URL that appears.
    ... or try the search function on the forum - but it's a bit naff IMO.
    For the windows take the door car off, search for guides, it's easy, 5 screws then lift off the card and careful unclip the wires and the handle cable. Have a look and see what's occurring.
    My brakes squeal, I just live with it. New pads made it almost disappear but not quite.
    When I got my S3 I had a garage do some bits on it and they told me I needed to spend £400 on some new fans as mine didn't work at all - I ignored them, googled, did some testing with a multimeter and found it was the fan controller, I got a fan controller for £25 from a breakers.
    You could probably do with a VCDS scan, you'll probably find all the common stuff will need doing if the car hasn't been looked after. vac & breather pipes, sensors, thermostat etc.
    HTH. Liam
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,563
    Don't forget to check out the stickies too...
    <tuffty/>
    Jan 2013
    Derbyshire
    Cheers guys, I'm booked in at JBS for a VCDS scan tomorrow, they're lead was broken today..
    I asked the guy if he had experienced my problems before, he said the fan could be the internal resistor failing, causing the fans to come on full blast upon a cold start, and be intermittent the rest of the time.
    Also the 'stuttering' issue, he asked when the spark plugs were last changed (I don't know as the dealer was a sack of....), possibly cool packs or MAF.
    Any of you guys have any suggestions? Think this diagnosis could be it?
    P.s I had a young kid in a mk6 gti come by me today booting it... I need my baby back
    Cheers! Conor.
    Jan 2013
    Derbyshire
    My PM function seems to be faulty, or does it have to be activated somehow?
    Tried to PM NHN about the VCDS lead, sent it off, checked my 'Sent Messages' folder and it has no history of any messages sent?
    Cheers.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,458
    Cheers.
    I will pm you how to change your settings. x
    May 2012
    RETFORD, NOTTS
    1,753
    Where abouts in derbyshire are you? i may be able to pop over this evening and run a scan if your not too far.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,003
    Cheers.
    In case anyone else would like you know how to save your sent PMs.
    How to Save Sent PMs
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Jan 2013
    Derbyshire
    Thank you folks for your input.
    I've just had Tom over checking my car with VCDS, I'd like to say a special thanks to him for dedicating his afternoon.
    The logs highlighted that I may have Oxygen Lambda sensor issues, possible water temperature sensor issue and misfiring on cylinder No.2.
    I will be servicing the car this weekend, so I'm probably gonna bang new Plugs and Packs in there too, take a look at this water temp sensor.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    Forum community spirit ftw
    May 2012
    RETFORD, NOTTS
    1,753
    Post those logs up, the second shorter one, im sure there are others on here more clued up with your engine, I drive a derv!
    But looks like coil pack possibly on cylinder 2, one had been changed previously to a cheapy aftermarket looking one, and o2 sensors looked iffy, possibly the exhaust blow not helping things there either.
    Not sure regarding the fans, they come on with the aircon, but dont activate with output tests on vcds. Temp rose to 96 c with no fans running still in vcds before i switched the aircon on. Rad was hot. no blown fuses. Maybe a relay somewhere controlling them or an iffy temp switch?
    Ive pm'd you about the replacement keys, but if you buy vcds yourself you will be able to program them yourself with the SKC code i pulled.
    Jan 2013
    Derbyshire
    Just been out and changed the Coilpacks and Spark Plugs, will be doing an engine service this weekend, give the poor girl some love..
    The 'stuttering' problem seems to have disappeared.... For now.... Horrreeyy!
    Next I will look into testing the Cooling fans, try and get them working as they should.
    Had a warning light come on today - 'Brake light failure'... But all three brake lights are working perfectly fine. This warning light doesn't stay on, only appears from time to time.
    May 2012
    RETFORD, NOTTS
    1,753
    Glad your coils fixed the issue :D
    Jan 2013
    Derbyshire
    Just got a slight oil weep from the Transfer Rear Output shaft seal (prop shaft to rear diff).
    Just wondering from a more experienced eye, looking at this parts picture (number 40945), theis number 5 (part number:
    09A409400
    the one I want?)
    Car is a 2002 BAM S3
    Audi - A3 - 2002 - The front axle, transfer case, steering Teilekatalog (ETKA Pats Catalog)
    Thank you.
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    595
    Jeez, no offence mate but it sounds like you bought a dog. I hope you got it cheap.
    Brake light issue, could be an issue with the switch at the pedal. This rings a bell from somewhere.
    ...... Now this one's MUCH better!...
    Jan 2013
    Derbyshire
    Aye pal, just been to JBS today and let them have a look at it for a pre-MOT inspection..... I needed to sit down!!!!
    The stuff mentioned earlier on is fixed now
    Now the more recent stuff haha!
    Got it for a reasonably alright price, but bit disappointing its all going wrong :P Old car... haha
    cjsuk's Avatar
    Feb 2012
    Leeds
    563
    For your window look here Broken window? Window clips? Window regulator? or motor? Guide inside that's my proud sticky most likely you have a similar problem but if not it covers just about everything for guidance
    Ill try stuff out! If you never try and never fail, you will never know and never learn.
    Jan 2013
    Derbyshire
    Thank you cjsuk, I appreciate that! Already gave it a read, just need to buy the bits. I had a look, it seems my regulator cable has chaffed through, causing it to snap.
    Going to mk4golfs.co.uk breakers in my town tomorrow, they specialise in mk4 golfs, S3, TT etc..
  1. Anyone got audi centre caps to fit to replica wheels?
    By adigraham in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2007, 16:16
  2. Anyone got an older red audi?
    By TonyT in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 11th February 2007, 22:13
  3. Anyone got there GF up the duff recently?
    By Soupie69uk in forum General Chat
    Last Post: 26th February 2006, 08:36
  4. has anyone got one of these fitted - Milltek Audi S3 98- CAT Back exha
    By DamoS3Q in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2005, 16:53
